11-07-2017, 03:14 PM | #1 |
1940 p/u rims
How much are 1940 p/u rims worth? I have a set of 5 with old bias ply tires on them. Looking to sell them. In great shape was using them till this year.
Thanks |
11-07-2017, 04:01 PM | #2 |
Re: 1940 p/u rims
Pickup rims are identical to passenger car rims. That makes them more desirable. IF they are truly '40 rims and in nice condition, the rims sell (typically) in the range of $35 - $50 each.
If you insist on leaving the tires on them, the shipping cost will of course reduce the number of folks so interested in their purchase.
11-07-2017, 04:45 PM | #3 |
Re: 1940 p/u rims
They are true 40 rims and in great shape. I was just going to list them local thanks for your help.
11-07-2017, 05:02 PM | #4 |
Re: 1940 p/u rims
Interesting, what are true '40' rims? and how are they different to 41 and later?
11-07-2017, 05:18 PM | #5 |
Re: 1940 p/u rims
That I don't know. I do know the history of the truck, and the rims were never changed.
11-07-2017, 06:06 PM | #6 |
Re: 1940 p/u rims
11-07-2017, 07:03 PM | #7 |
Re: 1940 p/u rims
I may be wrong but I believe the trucks have a star stamped at the valve stem hole, but other than that they are the same as the passenger car wheels. The reason on the star is debatable.
BILL WELLS |
11-07-2017, 07:23 PM | #8 |
Re: 1940 p/u rims
40 rims have a unique shape to their profile.
11-07-2017, 08:21 PM | #9 |
Re: 1940 p/u rims
As usual, you are correct Sir
It seems to me 1941 rims had that same profile. For a purist like myself, having a rim with a '41 date stamped in to it would not be acceptable. Yeah, I know- I'm strange that way.
11-07-2017, 08:25 PM | #10 | |
Re: 1940 p/u rims
On this '42-'48 wheel below, note that the two sides of the drop center are NOT parallel....one is vertical, and one is angled. The later wheels (below) are 4-1/2" BETWEEN beads. DD |
11-07-2017, 08:28 PM | #11 |
Re: 1940 p/u rims
Ahhh.......you ain't particularly strange.....you just know that "right is right"! You're right about the '41s being the same. DD
11-07-2017, 08:55 PM | #12 |
Re: 1940 p/u rims
Thanks for posting those great photos. That will help others to understand much better than descriptive words alone.
11-08-2017, 05:22 AM | #13 |
Re: 1940 p/u rims
Am I right in thinking there is an in between variant with the angled well side, but still only the 4" width? I'm sure I have a mixture of straight sides and angle sides but they are not 4-1/2".
Mart. |
11-08-2017, 06:47 AM | #14 |
Re: 1940 p/u rims
On the face of the wheel near the lug holes it should have a month and year stamped into the metal. That should let you know if they are 40 or not.
Thank God this is only a hobby! |
11-08-2017, 09:58 AM | #15 |
Re: 1940 p/u rims
This question is a bit off the topic. Are the narrow wheels for the V8-60 cars similar to the wider ones (profile represented in 01A wheel in photo above) in that first year of their type?
11-08-2017, 10:05 AM | #16 |
Re: 1940 p/u rims
1940-1942 Ford rims are 4 inches wide and 1946-1948 Ford rims are 4.5 inches wide. Fred Killian
11-08-2017, 10:09 AM | #17 |
Re: 1940 p/u rims
Yes. They have the same profile
11-08-2017, 04:20 PM | #18 | |
Re: 1940 p/u rims
11-08-2017, 04:32 PM | #19 |
Re: 1940 p/u rims
Mart.....I'm thinking you're right. I believe '42s (ONLY) are only 4" between beads. DD
11-08-2017, 05:19 PM | #20 |
Re: 1940 p/u rims
Yes, the profile is identical sans the width.
