05-20-2015, 06:09 PM | #1 |
Valve spring pressure sanity check
8BA with new valve seats, Manley Pro Flo valves with Chevy stems with one keeper groove. Cam will be a regrind, either L100 or 1007B. Street engine of 276". I'm checking spring pressure to see what more parts to order. I can only find rotator style keepers. I have non-rotator keepers somewhere that I haven't found yet. I have 1.934" installed height and 45# at installed height using rotator (short) springs and 75# using the longer spring. Opinions, please, on using the 75# pressure with the rotating keepers, or should I buy or find my non-rotator keepers and use the longer springs and shims and shoot for 50-55#?
05-20-2015, 07:01 PM | #2 |
Re: Valve spring pressure sanity check
I'd shoot for the 50 - 55 lb.
05-20-2015, 07:32 PM | #3 |
Ditto
05-20-2015, 07:40 PM | #4 |
If I shim the short spring at 45# am I likely to have coil bind on a .350 lift?
What thickness shim do you think it will take to turn the 45# into 50 #? Thanks for sharing your knowledge with us. |
05-20-2015, 08:05 PM | #5 |
50-60lb MAX !!!
Gene it is really not possible to guess accurately on what shim it would take ! Anyone can guess , but guessing is not how you build a great engine ! Coil bind is real bad also , as is valve hitting head ! Good Luck !! Cheers Tony |
05-20-2015, 08:11 PM | #6 |
05-20-2015, 08:20 PM | #7 |
Gene a .060 shim can substantially be different from spring to spring . Sorry to dissapoint but thats the way it can be. Just always like to be cautious !
05-21-2015, 06:33 AM | #8 | |
05-21-2015, 07:33 AM | #9 |
Why not measure it? You got X pounds at installed hight, now put more pressure on the spring till you get your desired poundige and measure the hight, the difference between this measurement and your initial installed hight will give you the shim thickness.
Martin. |
05-21-2015, 07:59 AM | #10 |
I doubt you can use a short spring o an L-100 without causing coil bind, never tried.
05-21-2015, 08:44 AM | #11 |
Thanks guys, long spring it is.
