Old 08-06-2018, 10:43 PM   #1
skeazle
Default Another spark plug question
I know this has been talked about many times here. I did a search here all the way back to 2010 - 2016 about the right plugs for the right heat range but has anything changed since then? I am currently running Motorcraft TT10's and I think I want to bump it up a tad in the heat range per the way I drive my '30 Tudor. The plugs are always black but never fouled up with soot or anything but since I only drive locally at slower speeds and RPM's would a hotter plug clean up the plugs a little? If I do get new plugs I was thinking maybe Champion W18's. By the way I just changed my gap from .032 to .035. I think someone on here said that is acceptable. Tomorrow I will take it for a spin. Thanks, Jim
skeazle is offline   Reply With Quote
Old 08-07-2018, 12:27 AM   #2
Drive Shaft Dave
Default Re: Another spark plug question
I also used the TT- 10, then switched to the hotter W-18. The TT-10 is too cold of a heat range.
Drive Shaft Dave is offline   Reply With Quote
Old 08-07-2018, 01:55 AM   #3
Mike V. Florida
Mike V. Florida's Avatar
http://www.fordgarage.com/pages/brum...kplugnotes.htm
Old 08-07-2018, 11:52 AM   #4
Purdy Swoft
Purdy Swoft's Avatar
Motorcraft TT 10 spark plugs were way too cold for my use . Champion W 18 spark plugs gave a noticable improvement in cranking and running for me .
Old 08-07-2018, 04:23 PM   #5
skeazle
Thanks for all the help guys. I did go to Napa today and get the last 4 Champion W18 plugs. I'll have to wait to take a drive when it is not raining. Does anyone know why when I click on a link all I get is a blank white page? Mike gave me a link to go to and there is nothing there. Maybe I don't have enough posts yet. Jim
Old 08-07-2018, 05:23 PM   #6
M2M
M2M's Avatar
Anyone ever used the Champion W20?
M2M is offline   Reply With Quote
Old 08-08-2018, 12:29 PM   #7
Purdy Swoft
I have not used the Champion W20 but it will be hotter than the W18
Old 08-09-2018, 07:34 AM   #8
JD 1931
JD 1931's Avatar
Used champion W-18 for years without any problems, gap at .035
JD 1931 is offline   Reply With Quote
Old 08-09-2018, 10:26 AM   #9
Purdy Swoft
I also run a gap of .035 regardless
Old 08-09-2018, 11:05 AM   #10
31a
I run the w16y at 35 and have not had any issues
31a is offline   Reply With Quote
Old 08-09-2018, 11:52 AM   #11
Kurt in NJ
Kurt in NJ's Avatar
Try closing the GAV more
I used to play with different spark plugs, only putting the 3X plugs in for show---- then one time I forgot , it ran better, idled better, and got better fuel mileage, no problems idling over hours of parades, and just fine at 65, averaged over 35 years of use they are cheap
Old 08-09-2018, 11:52 AM   #12
Kurt in NJ
Kurt in NJ's Avatar
Old 08-10-2018, 01:08 PM   #13
Ted Duke
Skezle,
Are you logged in? I f not it may NOT work correctly.
Ted Duke is offline   Reply With Quote
Old 08-10-2018, 09:29 PM   #14
jm29henry
jm29henry's Avatar
i love my champion 3x gaped at 35 both car run great
jm29henry is offline   Reply With Quote
