Old 09-03-2014, 11:02 AM   #1
Jack 34pu
Jack 34pu's Avatar
Default Gas resistant paint for tank?
I want to spray (rattle can if possible) my gas tank before putting it back in place. Is there a rattle can 'black' that will withstand some gas spillage? Possibly Tractor Supply or similar outlet?
Jack 34pu is offline   Reply With Quote
Old 09-03-2014, 02:53 PM   #2
B-O-B
B-O-B's Avatar
Default Re: Gas resistant paint for tank?
try some appliance epoxy. I think I seen gloss black, gloss white, satin stainless in wally world.
B-O-B is offline   Reply With Quote
Old 09-03-2014, 02:56 PM   #3
19Fordy
19Fordy's Avatar
Acrylic enamel with hardner worked for me.
Old 09-03-2014, 04:16 PM   #4
oldblue
oldblue's Avatar
An epoxy would probably be the most durable
49 Mercury M68 Pickup
oldblue is offline   Reply With Quote
Old 09-03-2014, 05:22 PM   #5
john worden
john worden's Avatar
If there is alcohol in the gas good luck.
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa.
john worden is offline   Reply With Quote
Old 09-05-2014, 09:03 AM   #6
Jack 34pu
Jack 34pu's Avatar
I was hoping someone could recommend a good industrial paint that could be applied before installing the gas tank. It is a Drake tank and has a silver paint or primer applied.
Old 09-07-2014, 02:13 PM   #7
supereal
supereal's Avatar
Do what Ford did. Use lacquer to paint the tank. It is fuel proof. Ford found that out when the gas tank was cowl mounted on the Model A where overfilling and ripping was a sure thing.
supereal is offline   Reply With Quote
Old 09-07-2014, 02:14 PM   #8
supereal
supereal's Avatar
Use lacquer. It is fuel proof. Ford discovered that when the filler on the Model A was put into the cowl.
Old 09-07-2014, 03:06 PM   #9
Kube
Kube's Avatar
Powder finish...
Old 09-08-2014, 12:35 AM   #10
Marvin/TN
Send a message via AIM to Marvin/TN
If Du Ponts IMRON is still available it will hold up brake fluid won't even touch it from what I have heard but it isn't in a rattle can
Marvin/TN is offline   Reply With Quote
Old 09-08-2014, 01:02 PM   #11
supereal
supereal's Avatar
We buy lacquer in rattle cans for use on parts exposed to gas.
