07-17-2019, 06:27 PM | #1 |
help with Mallory Unilite Distributor
I just purchased a Mallory Unilite and discovered it is 12 volt only. Not wanting to convert to 12 volts, I went to Holley's web site and discovered I can buy new points, condenser, and rotors for this unit. The only issue is that the unilite setup does not have a point cam on the shaft. Can I add a cam? where do I get one? Holley does not seem to offer one...
Frank |
07-18-2019, 05:46 AM | #2 |
Re: help with Mallory Unilite Distributor
Don't know anything about them. Does it say 12 volts?
https://www.jalopyjournal.com/forum/.../#post-2222729 |
07-18-2019, 06:54 AM | #3 |
07-18-2019, 10:25 AM | #4 |
You could get a 6V to 12V converter.
07-18-2019, 11:30 AM | #5 |
I would try and use points and condenser. I currently have a unilite and it starts fine but won't run under full throttle. I know of others that have had trouble with unilite.
07-18-2019, 11:54 AM | #6 |
07-18-2019, 01:24 PM | #7 |
I wonder if it could be converted to pertronix, they have 6 volt units.
07-18-2019, 01:43 PM | #8 |
That may be worth a shot....
