Old 07-13-2019, 10:29 AM   #1
wbs
Default wire wheels
hello- do model A wire wheels have any use other than for Model A's? I've got 7 or 8 that might go the scrap yard if no use
wbs is offline   Reply With Quote
Old 07-13-2019, 10:32 AM   #2
dubnutty
dubnutty's Avatar
Default Re: wire wheels
If your not going to use them, I sure could. Scrap yard!!
I'd go to the far ends of the earth for a GOOD beer.
dubnutty is offline   Reply With Quote
Old 07-13-2019, 10:37 AM   #3
katy
katy's Avatar
Some use them on model Ts w/adapters.
Old 07-13-2019, 11:03 AM   #4
ronn
I bolted one to the outside of the garage for extension cord...........
Old 07-13-2019, 12:23 PM   #5
redmodelt
redmodelt's Avatar
Value depends on size, condition and location.
Old 07-13-2019, 01:40 PM   #6
Joe K
Joe K's Avatar
The Model A 1928-29 wheels are probably a little rarer than the 1930-31 wheels - this due to their method of construction with an "inturning" rim bead. The bead catches water and the inturn bead rots out from the inside. The 1930-31 wheels do not suffer from this defect.
The Model A "AR" type wheels are probably the rarest in numbers and most difficult to find - but demand for these is limited because of the limited number of AR cars remaining. So value for these tend to follow the later 1928-29 wheels and probably for the same defect.
Around here a good usable 1928-29 standard wheel runs about $25. Better quality a bit more perhaps. AR wheels perhaps $35 when you find them. 30-31 wheels perhaps $25 but only if they not all chipped up on the paint.
Joe K
Shudda kept the horse.
Old 07-13-2019, 04:05 PM   #7
jhowes
Tell us where you are located and someone may want to come and pick them up.
jhowes is offline   Reply With Quote
Old 07-13-2019, 04:23 PM   #8
J Franklin
J Franklin's Avatar
Old rusty ones are gold at garden shops. They make good culvert screens Too! That is only a suggestion for damaged unusable wheels.
Old 07-14-2019, 05:44 AM   #9
wbs
thanks to all who replied
Old 07-14-2019, 02:07 PM   #10
monto
monto's Avatar
They have an inherent value. You'll do better selling rather than junking them, in my opinion, and most probably be of help to someone who is involved with A's.
'30 Coupe
monto is offline   Reply With Quote
Old 07-17-2019, 07:53 AM   #11
Dodge
They are also good buried in the ground as dead men to hold retaining walls. Cable around the retaining wall posts then back to the buried wheel.
They’ve been holding up ours since 1934. My Grandfather did it........,
Dodge is offline   Reply With Quote
Old 07-17-2019, 08:00 AM   #12
1928Mik
1928Mik's Avatar
Joe K, did not know that. I've got an extra set of NOS 28-29 wheels my Dad had in his garage. I had no idea they were of different construction.
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 07-22-2019, 11:07 PM   #13
Tom Wesenberg
Tom Wesenberg's Avatar
When they are rusted beyond use on a car, then they can be welded into a nice lawn chair.
Old 07-23-2019, 02:34 AM   #14
CarlG
CarlG's Avatar
Like this?
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 07-23-2019, 03:00 AM   #15
old31
Carl, that chair is awesome. Very clever.
old31 is offline   Reply With Quote
Old 07-23-2019, 08:02 AM   #16
rocket1
Weld them end to end and set your mailbox on top,cut one in half and wrap your garden hose around it.
rocket1 is offline   Reply With Quote
Old 07-23-2019, 08:29 AM   #17
Railcarmover
This one has bent spokes,should I scrap it too?
Railcarmover is offline   Reply With Quote
Old 07-23-2019, 09:15 AM   #18
Purdy Swoft
Purdy Swoft's Avatar
I would try to find someone that needed or wanted it before I scrapped it . Its not original model A .
Old 07-23-2019, 11:38 AM   #19
The Master Cylinder
The Master Cylinder's Avatar
I think you should find 3 or 4 more just like it and put them on your car. They look kinda 'Fancy'.
The Master Cylinder
Enjoying life at the beach in SoCal...
The Master Cylinder is offline   Reply With Quote
Old 07-23-2019, 05:27 PM   #20
d.
As stated above, a Model A wheel in any condition makes a great rack for an air hose, extension cord, etc. and it looks good doing it!
Any flea market, yard sale will give you $10 if they are that bad.
scrap yard is a loser move...helps no one
d. is offline   Reply With Quote
