12-02-2014, 02:12 PM | #1 |
electric engine clutch fan
Can anyone here give me some insight as to the longevity or practicality of using a electric belt driven engine fan, After reading the thread on the spare engine fan, I realized I have a N.O.S electric clutch fan, it apparently was originally sold from fred jones ford here in okla.city, I never took the time to install it.
fordestes |
12-03-2014, 10:58 AM | #2 |
Re: electric engine clutch fan
I assume you mean the accessory 1946-48 Ford Thermostatic fan offered by Ford. I have no experience running one of these fans, but I have had a few NOS ones in and out of the box. Most of the time when you find one of these fans the box has deteriorated and parts are missing. The most important piece is the temperature sensor/relay,(photo example) which is often missing from these units, usually the fan is found mounted to a piece of plywood and that's all you find. Maybe someone on Fordbarn has a installation instruction diagram.
12-03-2014, 08:53 PM | #3 |
I luckily have the sensor but I was thinking about using a newer sensor and a bosch relay set up I was wondering if it is worth the effort , it seems somewhat practical to
stabilize temp. and lessen the drag on the engine, We used this concept in the trucking industry for about the last 40 odd years to better control the temp and help the fuel milege. Fordestes, |
12-04-2014, 06:00 PM | #4 |
If they were popular, they wouldn't be rare today. Flatheads need all the radiator airflow they can get, so disconnecting the fan is hardly necessary.
12-04-2014, 06:51 PM | #5 |
Fordestes, |
