08-23-2014, 05:35 PM | #1 |
engine remove 1948 flathead
Can you remove engine and trans together or seperate .is there a pan that covers the clutch does that need to come off before removing engine? 1948 flathead :
08-23-2014, 05:58 PM | #2 |
Re: engine remove 1948 flathead
I removed the engine in 1947, Things I would do different remove the battery holder, and medal piece in front of radiator. I do think you can take both at same time. Someone will chime in.
08-23-2014, 11:57 PM | #3 |
We put the engine/trans combo back in my '47 convertible as a unit. It wasn't too difficult at all, a little maneuvering and wiggling got it done. We removed it as a unit also.
08-24-2014, 08:44 AM | #4 |
Flyboy89,
Did you remove the front clip or just the hood? Kevin
"Failure is simply the opportunity to begin again, this time more intelligently". Henry Ford. |
08-24-2014, 12:58 PM | #5 |
Hood, radiator and upper deflector that sits in front of the radiator come off. If you remove the entire front clip, getting the hood to fit will open a whole set of problems.
08-25-2014, 05:39 PM | #6 |
08-25-2014, 05:46 PM | #7 |
remove the rad first or buy a new one later.
