06-09-2013, 09:37 AM | #1 |
Distributor install
Hi all
When installing a new distributor the advance rod from the firewall does not reach the distributor attachment? Any direction is appreciated |
06-09-2013, 10:07 AM | #2 | |
Re: Distributor install
The slot in the distributor cap is what sets the "degree of action" of the distributor. As long as moving the lever at the steering column keeps the distributor lever within the range given by the cap - you're fine. Assuming your connector is original length. I think I had a repop connector once that was too long. To turn the column would have put the levers at a most unnatural angle. So I put a bend in the connector. This worked until I could get an oem connector. Joe K
Shudda kept the horse. |
06-09-2013, 10:23 AM | #3 |
If you have the two tooth steering, there is a clamp where the column tube meets the steering box. loosen the two screws that hold the clamp under the gas tank or upper dash if it is a mid to late 1931. Loosen the tube clamp at the bottom of the steering column tube. After loosening the clamps you should be able tro rotate the steering column tube and bring the advance rod closer to the distributor connection. There is an opening or window at the rear of the distributor cap body that the arm of the upper distributor plate moves in. You should be able to rotate the column tube so as to gain full advance and retard of the distributor plate lever inside this window in the distributor cap. If adjusting the column tube doesn't give full movement, the only other possibility would be that you have the wrong or too short of advance rod.
06-09-2013, 10:28 AM | #4 |
Sorry Joe K. , I'm typing slow, not lring to be an echo.
06-09-2013, 10:36 AM | #5 |
Hi Joe
The original one fit perfectly The top dist plate does not rotate now, I pushed down on it, does that make a difference? |
06-09-2013, 11:15 AM | #6 |
Paul in CT |
06-09-2013, 12:11 PM | #7 |
The upper plate rotates in a groove in the distributor housing. The plate has three tabs. with the cap and rotor removed, looking straight down at the distributor houseing you will see the groove with three reliefs, indentations that allows the upper plate to be removed. There is a spring between the upper and lower distributor plates, This spring holds tension on the upper plate for stabilazation of the tabs on the upper plate where it rotates in the groove in the housing . If the cap is removed, the upper plate can be rotated until the tabs align with reliefs , this causes the spring loaded upper plate to jump the groove in the housing. The plate may have somehow jammed the plate tabs in the grove so that it no longer rotates. You should be able to carefully push down on the plate and work the tabs back in place so that the upper plate will function again.
06-09-2013, 01:03 PM | #8 |
No apologies necessary everyone. The limitations of the media.
Plus one on Purdy's explanation. With everything assembled you should be able to move the advance/retard arm on the distributor with your fingers - the slot in the black plastic cap is the limit(s). And keeps the plate from finding the three removal grooves when assembled. Joe K
