12-26-2023, 10:09 AM | #1 |
Looking for a General Purpose Puller Tool
I’m trying to prepare for future repairs, and I’m looking for a general purpose puller tool. Nothing needs fixed at the moment, but it would be great to have the proper tool on hand when I eventually need it. I have something similar to this:
Performance Tool W137P 6-Inch 3-Jaw Gear Puller with Reversible Design for Vehicle Maintenance and Repair, Drop-Forged Steel, Chrome Plating https://www.amazon.com/DURATECH-Remo...1zcF9hdGY&th=1 That tool didn’t work on rear brake removal; so, I purchased a heavy duty drum puller for those a while back. I also purchased wheel bearing race removal and installation tools from Bratton’s a while back. I’m thinking about purchasing something like this: CWTRLPC 21 in1 Bearing Puller Kit, Bearing Removal Tool, Bearing Separator Set, Bearing Disassembly Gear Puller w/ 3-jaw Hooks and 6 Sizes Red Steel Inner Hole Extractor https://www.amazon.com/dp/B0BYJX8T17...v_ov_lig_dp_it Or Orion Motor Tech Bearing Puller Set, 5 Ton Capacity Bearing Separator, Pinion Wheel Bearing Removal Kit with 2" and 3" Jaws, Wheel Hub Axle Puller Set, Heavy Duty Bearing Splitter Tool Kit https://www.amazon.com/dp/B0B2DF6LXT...v_ov_lig_dp_it At some point, I will probably need a puller to remove the rear bearing in my Tremec T170 transmission. (It doesn’t leak now, but I drive the car a lot; so, eventual replacement will likely be necessary somewhere down the road.) For what other parts would I likely need a puller tool on a Model A? Can anyone suggest a general purpose puller that works well on Model A applications? Sent from my iPhone using Tapatalk Last edited by shew01; 12-26-2023 at 10:16 AM. |
