09-19-2017, 09:26 PM | #1 |
Can anyone identify this?
Hey fellas, just ran across this Model A for sale on on Craig's list and in this picture of the right side of the engine I noticed the timing gear side cover was replaced with something? Looks like there's a wire connected from a lever on it to the choke rod. what is this? Just curious....... Thanks!
09-19-2017, 09:36 PM | #2 |
Re: Can anyone identify this?
That is a governor, often used on farm equipment, combines, and industrial engines.
09-19-2017, 09:38 PM | #3 |
Could be a governor
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
09-19-2017, 09:46 PM | #4 |
Thanks guys! Would this have been to limit speed? or maintain RPMs under load?
09-19-2017, 11:27 PM | #5 |
Maintain Rpm's under load.
There is a knob on the end that increases or decreases rpm's depending on the speed you need. These are common on the Air Compressors that used the two center cylinders to pump air and the two outer cylinders ran as normal on gasoline.
"If I asked people what they wanted they would have said faster horses." -Henry Ford "Primitive technology is not a design flaw" 1928 Ford Model A Roadster Pickup 1930 Gordon Smith Air Compressor 1941 Willy's Pickup 1960 Thunderbird-For Sale 1964 Buick Riviera 2x4 425 1965 Pontiac GTO, 455 Super Duty 2004 Dodge Ram SRT-10, V-10 Viper 1977 Charger Jet Boat,460 Ford,Jacuzzi Jet Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford Engine Build up on DVD ask |
09-20-2017, 03:12 AM | #6 |
09-20-2017, 06:27 AM | #7 |
I think it's probably just hooked up wrong,not doing anything.What interests me is the way the distributer is installed.I noticed that before the governor.
09-20-2017, 07:35 AM | #8 |
I wuz once the "Chief Governor Overhauler" , on the Hercules QX-D3 engines in John Deere Cotton Pickers. The innards are QUITE INTERESTING!
I've fixed a LOT of WEIRD stuff! Bill Jackofalotofstuff
09-20-2017, 01:32 PM | #9 |
May be cruise control !
09-20-2017, 03:34 PM | #10 |
