10-15-2023, 01:09 PM | #1 |
1939 generators?
I'm trying to identify these two generators and their applications. On the left is a 3 brush with T2 date code (Feb 1939). It has 4-3/8" diameter fan mount pulley, keyed with nut. On the right is a 2 brush, no date code found yet. It has a single terminal post on the side and one on the back. A 3-1/8" diameter screw on non-fan pulley with clip. The pulley is sheet metal, not cast. Perhaps aftermarket?
My intent is to rebuild and offer them for sale, but want to be sure of their application. Appreaciate any help. Thanks, Steve |
10-15-2023, 01:28 PM | #2 |
Re: 1939 generators?
The one set up for a fan and cutout is a standard, the deluxe had the fan on the crank I believe. The 39 deluxe would have a T code, 40 would have a U.
10-15-2023, 02:53 PM | #3 | |
10-15-2023, 03:21 PM | #4 |
This is a correct 39 Deluxe generator. Cast pulley held with a nut unlike the later ones that use a threaded pulley.
10-15-2023, 03:43 PM | #5 |
So this may be a 1940 deluxe? It has the single terminal post and threaded on pulley.
10-15-2023, 03:52 PM | #6 | |
01A prefix on the part number and both were cast. Also the 40 generator mount will have an 01A prefix |
10-15-2023, 04:20 PM | #7 |
10-15-2023, 04:21 PM | #8 |
10-15-2023, 04:47 PM | #9 |
The mounting bracket does have the 01A prefix.
10-15-2023, 05:01 PM | #10 |
Steve, the one with the steel pulley (incorrect) is most likely '40. The only way to be certain is to check the date code as has been previously advised.
The other is most likely '39 standard. Again, to be certain, you'll need to check the date code. The '40 is not worth the cost of rebuilding it properly. The '39 might be IF you can find a buyer.
10-15-2023, 05:07 PM | #11 |
Kube - thanks. The black 3 brush has a T2 code, Feb '39. So it is for a standard '39? Good to know. I partially wire brushed the other one, but not found a code. I read sonewhere that the single terminal was a one or two year thing. But dont recall the details.
10-15-2023, 05:11 PM | #12 | |
The two-post body was '39 deluxe, '40 all and '41 all. But again, most guys don't care if it's correct. '42 - '48 generators fit and function and are cheap.
10-15-2023, 05:16 PM | #13 | |
10-15-2023, 05:23 PM | #14 |
Kube - just so I'm clear, when you say two-post body, you mean one on the side and one out the back of the brush plate? That looks like your photos.
39 Deluxe would be T code. 2 brush, pulley keyed with nut, 2 terminal posts total. Correct? Thank, appreciate the education. |
10-16-2023, 07:33 AM | #15 |
Kube - just so I'm clear, when you say two-post body, you mean one on the side and one out the back of the brush plate? Yes sir. That looks like your photos.
39 Deluxe would be T code. 2 brush, pulley keyed with nut, 2 terminal posts total. Correct? Correct. Thank, appreciate the education.[/QUOTE]
10-16-2023, 07:51 AM | #16 |
Wasn't the 39 the first yr for the voltage regulator std as well as deluxe, If so the std would be a 2 brush generator.
10-16-2023, 10:03 AM | #17 |
If that is the case, what is this Feb 1939 (T2 code) 3 brush generator for?
10-16-2023, 10:29 AM | #18 |
That appears to be a gen for a 39 standard which uses a cutout.
10-16-2023, 10:47 AM | #19 | |
10-16-2023, 10:59 AM | #20 |
This is where I'm confused. I see conflicting information regarding the '39 standard. Does it use a 2 brush or 3 brush generator? If 2 brush, what does this T2 code generator go on?
I'm looking at the Green book. If I'm interpreting it correctly, '39 standard uses the 81A-10000-A (3 brush generator), while Deluxe used the 81A-10000-D (2 brush). Last edited by ndnchf; 10-16-2023 at 11:08 AM. |
