Old 07-30-2013, 02:54 PM   #1
36tudordeluxe
36tudordeluxe's Avatar
Default How to install rear brakes on Ford 8"?
Could someone give me the proper sequence for installing rear brake shoes on a Granada 8"? Do I install shoes to backing plate & then install upper springs or do I put bottom spring in first?
36tudordeluxe is offline   Reply With Quote
Old 07-30-2013, 10:04 PM   #2
parklane
parklane's Avatar
Default Re: How to install rear brakes on Ford 8"?
I always install the shoes on the backing plate first, then install the self adjuster, then the springs. BTW short shoe goes on the front.
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
Old 07-30-2013, 11:24 PM   #3
ford3
i install the bottom spring to he shoes with the adjusters installed, and emergency brake cable installed to one shoe, spread shoes install on the backing plates, then the holding pins, then last the oblong washer and heavy spring that goes to both shoes
ford3 is offline   Reply With Quote
Old 07-31-2013, 12:00 AM   #4
36tudordeluxe
Thanks guys, I'll be back in the garage in the morning.
Old 07-31-2013, 08:11 AM   #5
Ole Don
Ole Don's Avatar
And wear your glasses. Those springs can do strange things.
Ole Don is offline   Reply With Quote
