Old 07-23-2013, 03:40 PM   #1
dono50
dono50's Avatar
Send a message via MSN to dono50
Arrow 302 engine compatibility question
I have to replace the 302 engine in my 70 mustang with C4 tranny. Will an 1989 302 engine bolt up to the 70 C4 tranny?
dono50 is offline   Reply With Quote
Old 07-23-2013, 04:45 PM   #2
Jay in Mass
Default Re: 302 engine compatibility question
Yes a 289 will fit....As long as it is not the very early 260 type which has 1 less bolt on the bell housing.
Jay in Mass is offline   Reply With Quote
Old 07-23-2013, 06:49 PM   #3
Y-Blockhead
Y-Blockhead's Avatar
Is you CRAZY...
Old 07-23-2013, 07:08 PM   #4
craig
yes, it will bolt up. Just remember that the 89 engine has a 50 oz imbalance and the 70 is a 28 oz imbalance. You must use the proper flexplate, you can buy an aftermarket 50 oz flexplate to fit you c4 convertor. If you must change the harmonic balancer, same rules apply and you can buy a 50 oz balancer with the correct offset for your application
craig is offline   Reply With Quote
Old 07-24-2013, 04:16 PM   #5
JeffB2
JeffB2's Avatar
Your 1989 donor already has the 50 oz balancer but you will need this: http://www.kmjent.com/cart/ford-sfi-...0l-c4-aod.html Because your Mustang uses a front sump oil pan you will need to use it and the oil pump pickup and timing cover and dipstick from your '70 engine and remember to plug the side dipstick hole on the '89 donor.Also if you are going to retain the intake and Carb from the '70 and manual fuel pump you may want to use the early timing chain and eccentric.
JeffB2 is offline   Reply With Quote
