07-03-2013, 02:13 PM | #1 |
5.0 motor EFI
I put a 5.0 EFI motor in my 47 ford. the last time it ran was about a month ago. I disconnected the battery at the upholstery shop, and I reconnected the battery and started the engine it when full throttle. WHY? need help please
07-04-2013, 04:58 PM | #2 |
Re: 5.0 motor EFI
since it has a mechanical throttle valve, it couldn't actually go "full throttle" unless it was manually opened. The electronic air control solenoid will kick up the idle, but would be incapable of a complete "full throttle"
07-04-2013, 06:12 PM | #3 |
Re: 5.0 motor EFI
I hear what you are saying.....the throttle body valve was closed and the engine reved to about 5K RPM
07-04-2013, 08:33 PM | #4 |
Re: 5.0 motor EFI
The computer probably has to reset itself. Sometimes you have to take it on the road for this to happen.
07-05-2013, 02:22 AM | #5 |
Re: 5.0 motor EFI
Try this article:http://www.muscularmustangs.com/idlereset.php
07-06-2013, 10:39 AM | #6 |
Re: 5.0 motor EFI
07-27-2013, 09:17 AM | #7 |
Re: 5.0 motor EFI
Is the EFI speed density or MAF? How long does it stay at the elevated RPMs? Start it, let it run for a few seconds (10 - 15), shut off, restart. Both systems have a "cold start" mode and need a moment to settle in. My speed density system would bring the engine up to around 2500 - 2800 after the battery was disconnected and took a couple of restarts to get it to settle in to a proper idle. After the computer "learned" all of it's parameters it still fired up to 2500 then immediatly settled into a normal idle.
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II |
