Old 06-01-2013, 07:31 AM   #1
Jon-Ohio
Default Horn - voltage reducing resister
Was wondering what size (ohms and watts) resister is needed to drop 12 volts to 6 volts for a Model a horn ? Would like to get one locally instead of the hassle (and high cost) of ordering one from a parts supplier.
Thanks - Jon In Ohio
Jon-Ohio is offline   Reply With Quote
Old 06-01-2013, 10:36 AM   #2
steve s
steve s's Avatar
Default Re: Horn - voltage reducing resister
I just grabbed a big one out of my junk resistor box and it worked ok.
Let's see if we can figure it out:
You want a 6 volt drop E across resistance R for about 6 amps of current I.
E = I R or R = E/I = 6/6 = 1 ohm.
Adjust to suit your horn's current draw. It helps to have a few extra volts for the horn for use at idle or low speeds.
Power equals current-squared x resistance, which for above calculation indicates a 36 watt resistor (or larger). I think you could get away with lower rating as long as you don't blow the horn continuously--give the resistor time to cool down.
Steve
steve s is offline   Reply With Quote
Old 06-01-2013, 11:44 AM   #3
jrelliott
jrelliott's Avatar
On Ohmite RKS2RO or go to www.studebaker-info.org/tech/6-12V/6-12-6.htrr for an electronic voltage regulator
jrelliott is offline   Reply With Quote
Old 06-01-2013, 03:03 PM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Somewhere, I read, that a "hidden" ignition coil makes a good horn resistor?? Bill W.
"THE ASSISTANT GURU OF STUFF"
