Old 04-20-2018, 12:03 PM   #1
kp
kp's Avatar
Default kp
Disassemble wiper tower on 40 Ford for new Chrome ,how do you remove the small chain ?
kp is offline   Reply With Quote
Old 04-20-2018, 12:12 PM   #2
19Fordy
19Fordy's Avatar
Default Re: kp
It's been 40 years but, as I recall, when you unbolt the towers from the cowl, the chain develops slack and is easily removed from the little wheels. Take photos before you remove anything and on't lose the little springs and things. Don't "force" or Z"pry" anything.
Old 04-20-2018, 12:34 PM   #3
kp
kp's Avatar
Default Re: kp
have removed the towers ,wanting to get them rechromed ,cant seem to disasemble towers .I see how to remove the chain but how do you remove the shaft that goes thru the tower ? appear to be MADE on the tower .Gotta be a way to remove .Thanks for answering so soon!
Old 04-20-2018, 05:11 PM   #4
19Fordy
19Fordy's Avatar
Default Re: kp
kp: I never removed the tower shaft so can't help on that. Are you sure you need to remove the shaft for chrome plating? Can't the plater tape it off or cover it in some way so that only the front part of the tower is plated? Rather than get my originals rechromed I bought a set from BOB DRAKE about 35 years ago and they still look and work fine. Less expensive than rechroming also.
https://www.bobdrake.com/40wipertower
Old 04-20-2018, 06:23 PM   #5
deuce_roadster
deuce_roadster's Avatar
Default Re: kp
Years ago I did have some towers rechromed and disassembled them. The shaft that the arm bolts to is pushed into a sprocket the chain goes around and has tight fitting splines. If you make a puller to pull outward pressure on the shaft it will come out of the sprocket with the chain and both will fall out the bottom. I think I used washers and the threaded part of the shaft to accomplish this.
Old 04-21-2018, 10:03 AM   #6
rotorwrench
rotorwrench's Avatar
Default Re: kp
Platers can use wax to cover stuff not to be plated but complete disassembly is always prefered if possible.
Old 04-23-2018, 10:38 AM   #7
kp
kp's Avatar
Default Re: kp
Thanks for all the replies ,may just let the plater cover the inside part ,only needs outside part plated .
