Old 06-10-2016, 07:40 PM   #1
Randall
Randall's Avatar
Default Brake lathe
does anyone here know what make and model lathe that will turn rear drums for model A?
Thanks
Randall is offline   Reply With Quote
Old 06-10-2016, 08:04 PM   #2
Glenn C.
Glenn C.'s Avatar
Default Re: Brake lathe
We had a Sunnen Brake Drum Lathe, but found it easier to do the job with an ordinary machine shop engine lathe
Glenn C. is offline   Reply With Quote
Old 06-10-2016, 09:39 PM   #3
Don/WI
I have an Ammco Brake Lathe that does a good job on front and rear model A brake drums. I have done quite a few for club members over the years. I have seen them for sale occasionally on e-bay and even on Craigslist a few times. Don/WI
Don/WI is offline   Reply With Quote
Old 06-10-2016, 09:59 PM   #4
Bob C
Ammco will if you install the 11/16" spindle.
Bob
Old 06-11-2016, 01:06 AM   #5
Mitch//pa
Bob
Correct
Here is the info you need for the aamco
http://fordbarn.com/forum/showthread...ght=rear+drums
Old 06-11-2016, 02:10 AM   #6
Dodge
I do them on my Ammco with the small spindle installed.
Dodge is offline   Reply With Quote
Old 06-11-2016, 07:44 AM   #7
Kurt in NJ
Kurt in NJ's Avatar
The Barrett/jim beam works well, the adapter you can see on the left top fits in the rear wheel bearing so the seal doesn't even have to be removed
Old 06-11-2016, 02:34 PM   #8
Don/WI
I don't know what size the spindle is and I'm not home to check, but I know the outer end needs to be small for the adapter used on the rear hub. Don/WI
Old 06-11-2016, 09:11 PM   #9
Randall
Randall's Avatar
Thanks fellow's !
