Old 10-08-2016, 01:03 PM   #1
fbl
Default Jay Lubricator
I have a 29 roadster ( first time ) with a Jay Lubricator and not sure what kind of oil goes in it and how to get in it to put the oil in, will try to post picture later Help thanks, Fred
fbl is offline   Reply With Quote
Old 10-08-2016, 04:15 PM   #2
Jerry in Shasta
Jerry in Shasta's Avatar
Default Re: Jay Lubricator
Goggle Jay lubricator
Connoisseur of Rust
Jerry in Shasta is offline   Reply With Quote
Old 10-08-2016, 08:48 PM   #3
MikeK
MikeK's Avatar
Your first post! Welcome Fred!
There are two styles of Jay lubricators that I know of. (I collect lubricators) Either you have a round dome two part metal device in which the bottom half unscrews to fill, or you have the glass version. The all metal one is based on US patent 1,753,718 issued to S.H. Paxton.
The design is extremely complicated internally. Operation is far superior to the lowly Ampco oiler and similar to the Marvel inverse oilers. I suggest you research the patent for details. Basically it provides a constant oil feed rate. I can't say for sure but I believe the original 'Jay' oil was a compounded oil consisting of various plant oils like castor and methylated organic acids to form esters. I don't know the base carrier but likely it was a 1920's petrol non-cat crack straight distill based derivative.
You could use MMO or two-cycle oil in it. Explaining how to adjust it would fill pages... Read the patent description.
MikeK is offline   Reply With Quote
Old 10-08-2016, 10:58 PM   #4
Mike V. Florida
Mike V. Florida's Avatar
Welcome Fred!!
A post in the AACA forum states " Usually filled with Marvel Mystery Oil, Redex, Bardahl or similar."
Old 10-09-2016, 02:01 AM   #5
pooch
pooch's Avatar
These remind me of our LPG (propane/butane mix) that OZ servos (gas stations) flog (sell) here..
Ours are a vacuum operated drip feed of a so-called valve saver snake oil.(supposed lead substitute )
They were not needed when cars were factory built with hardened exhaust valve seats , when the ADR (OZ govt, automotive rule )was mandated in 1986 that all new cars must run on unleaded fuel.
Do not see them much anymore as the govt. has just about kiled off the LPG benefit by hiking up the local price and selling it for a pittance to China..
pooch is offline   Reply With Quote
Old 10-09-2016, 07:20 AM   #6
Dollar Bill
Dollar Bill's Avatar
I recommend using ATF in the oil injector. It has cleaning and lubrication properties that are better IMO than MMO or other additives often referred to here on the Barn.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 10-09-2016, 07:22 AM   #7
WTSHNN
WTSHNN's Avatar
I found some era pics of these installed on a Model A Special Delivery. You can see them here...
https://www.fordbarn.com/forum/showpo...&postcount=601
-Tim
No one wants advice - only corroboration.
-John Steinbeck
WTSHNN is offline   Reply With Quote
Old 10-09-2016, 05:12 PM   #8
fbl
I want to post a picture of the lubricator and have gotten it to a album, got to figure how to get it in the post. My jay has a metal top with a glass bottom and is smaller than some of those already posted. We are in some of the flood area and had to deal with a inch of water in the basement which has detracted me for a while. Thanks Fred
Old 10-09-2016, 05:16 PM   #9
Mitch//pa
Here is the pic of Freds "" jay lubricator"""
Old 10-09-2016, 05:28 PM   #10
fbl
How did you post that or what did I do to get it done? Fred
Old 10-09-2016, 05:32 PM   #11
Mitch//pa
http://fordbarn.com/forum/faq.php?fa...b3_attachments
Old 10-09-2016, 07:19 PM   #12
MikeK
MikeK's Avatar
OK, now that we know which model it is here's what is inside. Look up the patent description to find out how it works & how to adjust it.
Old 10-10-2016, 06:45 PM   #13
Mikeinnj
Mikeinnj's Avatar
The EPA must have nightmares when they see one of those devices.
Mikeinnj is offline   Reply With Quote
Old 12-07-2021, 07:20 PM   #14
billhoniotes
Mike - I have an incomplete Jay Lubricator on my 1927 Willys-Knight I've just purchased. It appears to only be missing the glass jar? Any info on operation and adjustment ? I can send you a photo.
billhoniotes is offline   Reply With Quote
Old 12-08-2021, 09:21 AM   #15
nkaminar
nkaminar's Avatar
For a discussion about different oilers and how they work and what to put in them, see https://www.fordbarn.com/forum/showthread.php?t=307166
Old 12-08-2021, 11:17 AM   #16
duke36
Decades ago the Restorer magazine had an article about adding a PCV valve from the valve cover to the wiper port on intake manifold. It may potentially aspirate oil mist into the manifold and perhaps do a similar job including fouling the spark plugs.
duke36 is offline   Reply With Quote
Old 12-08-2021, 11:27 AM   #17
katy
katy's Avatar
Please note that this thread is 5 years old.
