07-01-2016, 12:28 PM | #1 |
Manifold Replacement?
My exhaust manifolds on my 8Ba are cracked and in bad shape. Are they known for breaking upon removal or do I have a chance at getting these out with minimal problems? Anyone have a suggestion? Thanks. Luke
07-01-2016, 12:32 PM | #2 |
Re: Manifold Replacement?
Find a replacement before you try taking the old ones off. Probably better than trying to weld yours.
Charlie Stephens |
07-01-2016, 12:35 PM | #3 |
Im not going to repair them, I bought a replacement set last year already, just wondering how hard they come out.
07-01-2016, 02:16 PM | #4 |
Mustang8:
If your new manifolds don't work out post a picture of originals and I will look in the shed. I see your in Wisconsin come pick up a set, free to good home. Dave/Green Bay |
07-01-2016, 02:32 PM | #5 |
You can be assured that the bolts will be a bugger to get out but because you are going to toss the old ones, you can break them apart to get at those stubborn bolts if needed.
07-01-2016, 02:45 PM | #6 |
07-01-2016, 02:46 PM | #7 |
07-01-2016, 03:15 PM | #8 |
Exhaust bolts can be the hardest bolts to remove on an engine.
07-01-2016, 04:26 PM | #9 |
If you break off a bolt, don't be surprised. They go thru many, many heat and cool cycles which anneals them and makes them soft. We see a lot of them at our machine shop. if not enough sticks out to use a vice grips on it, we weld a nut to the stub. The heat of the welding helps loosen it up. You don't have to pull the motor.
07-01-2016, 06:16 PM | #10 |
Use lots of 50/50 mix over a few days make sure you ude a 6point socket, you might have to make one to fit.
07-01-2016, 09:12 PM | #11 |
I seldom have had a problem with exhaust manifold bolts. You've got a better than average chance of getting them out without breaking one.
07-05-2016, 07:20 AM | #12 |
Huh sounds pretty promising! Probably give it a shot after the Iola Old Car show swap meet this weekend.
07-05-2016, 08:07 AM | #13 |
And when you put on the new set, use brass nuts; At a minimum they will be easy to turn off (with a little heat) and not break the studs.
07-05-2016, 09:21 AM | #14 |
X10. The stuff works.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. " |
07-05-2016, 09:28 AM | #15 |
Whats the 50/50 mix?
07-05-2016, 09:43 AM | #16 |
Acetone and ATF, auto trans fluid...... Mark
07-05-2016, 12:20 PM | #17 |
I recently has some lawnmower blades that wouldn't come off with my impact wrench. I put some 50/50 on it waited 10 minutes and all 3 came right off. I wouldn't believe it if I didn't see it.
