Old 12-26-2019, 08:32 PM   #1
1935TOWtruck
Default Wiring
Need some wiring advice have 1935 harness want to wire 1940 motor have new voltage regulator will this work this year thanks
1935TOWtruck is offline   Reply With Quote
Old 12-26-2019, 09:21 PM   #2
Tinker
Tinker's Avatar
Default Re: Wiring
Long and short. No. Need a engine harness to match (regulator, etc), not the yr vehicle harness. best of luck!
Old 12-26-2019, 09:49 PM   #3
tubman
tubman's Avatar
Default Re: Wiring
Actually, you could figure out how to modify the existing harness if you absolutely had to (already own it, no possibility to return), but Jess is right; you'll be better off with the correct harness, if there is one available.
Old 12-26-2019, 09:54 PM   #4
Tinker
Tinker's Avatar
Default Re: Wiring
Denny I agree. But I personally like to have a harnesses complete. But if you have some wiring skills you can make it look great and work! yes it is possible. It is easier to change some extras, like lights then the charging system sometimes... and sometimes I'm wrong too. Hope you had a great christmas!
Old 12-26-2019, 10:23 PM   #5
1935TOWtruck
Default Re: Wiring
Thanks everyone
Old 12-27-2019, 03:09 AM   #6
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Wiring
its simple, make a 3 wire harness for generator to regulator (arm, fld, ground), take the 35 generator wire and connect to "bat" terminal on the regulator
Old 12-27-2019, 11:08 AM   #7
JSeery
JSeery's Avatar
Default Re: Wiring
Unless you get a custom wiring harness I would think the easiest approach would be to use the harness for the vehicle model year and just add the wiring required for the generator. It only involves a few additional wires like Kurt posted. You can purchase wiring that will match the wiring style of your harness.
