12-25-2014, 05:59 PM | #1 |
1941-48 brake/clutch assembly?
Hi,
Does anyone have close at hand the part numbers for the 1941 throught to 1948 brake/clutch pedal assemblies? Are they similar in configuration as the OIA -O9A series? thanks |
12-25-2014, 07:59 PM | #2 |
Re: 1941-48 brake/clutch assembly?
Not sure there is an "assembly" number. The Bracket part is 01A 2473, the Brake Pedal is 09A 2455 and the Clutch Pedal is 01T 7550. Then there are a lot of smaller parts. Is this what you were looking for? These are Pass parts.
12-25-2014, 08:27 PM | #3 |
So, is then the bracket number (O1A) from the 1940, carried right through from 41 to 48???
Basically, if the part numbers are a carry over then I can use the 41-48 assembly in my 40. |
12-25-2014, 08:48 PM | #4 |
If possible, get a copy of the BIG GREEN BOOK and examine the part numbers for the years 1940-48. 1940-48 all have the same parts configuration as shown in the pictorial drawings. However, there may be some subtle differences. Here's one for a very cheap price.
http://www.ebay.com/itm/Green-Bible-...f5779c&vxp=mtr |
12-25-2014, 09:00 PM | #5 | |
Sorry 19Fordy, unfortunately dont have a copy down here, hence asking here on the Fordbarn at this time.
12-25-2014, 10:11 PM | #6 | |
09A 2473 41-48 Pass (Bracket and Shaft Assy) 01A 2473 40-48 Pass & 40-41 Comm (Brake Pedal Arm) 01T 7520 40-47 All (Clutch Pedal Arm) Last edited by JSeery; 12-25-2014 at 10:20 PM. |
12-25-2014, 10:30 PM | #7 | |
http://www.ebay.com/itm/28-30-31-32-...640ee1&vxp=mtr |
12-25-2014, 10:30 PM | #8 |
12-25-2014, 10:31 PM | #9 |
