05-10-2016, 09:24 PM | #1 |
8BA oddity
Just got an 8BA built and was cranking it to check oil pressure. No pressure and then I noticed oil running out of the bellhousing. Now what the H--- did I do wrong? Well I removed the flywheel and there was a 1/8 pipe thread hole in the block behind the oil distribution tube. Has anyone else ever seen this?
05-11-2016, 06:51 AM | #2 | |
Re: 8BA oddity
05-11-2016, 08:18 AM | #3 |
Re: 8BA oddity
Yep, I've got it plugged off. Just had never seen it before. Thanks for the info, something new all the time.
05-11-2016, 08:19 AM | #4 |
Re: 8BA oddity
Is this different from the gallery plug at the back of the block that blocks off the main oil tube that runs down the center of the valley?
05-11-2016, 12:08 PM | #5 |
Re: 8BA oddity
The earlier engines had that plug. Normally the 8BA only has a plug in the front of the block.
05-11-2016, 12:10 PM | #6 | |
Re: 8BA oddity
05-11-2016, 03:37 PM | #7 |
Re: 8BA oddity
All the 8BA's I've had apart had the plug, including the EAB that's in my truck.
Edit -- I take that back, I just found a picture of a '50 Car block I have and it doesn't have it.
'52 F-1, EAB flathead |
05-11-2016, 05:23 PM | #8 |
Re: 8BA oddity
That's not where the hole is in my block. It is above the cam drive cover and and deeper in the block. I don't think that picture you have is of an 8BA. Believe it is an earlier engine..
