Old 10-03-2023, 06:31 PM   #1
Steves46
Steves46's Avatar
Default Steering Support Bracket Question
I have a 30 Coupe and although I have not had any issues with fuel leaks resulting from the steering support bracket riveted to the gas tank, I am thinking about getting the 1931 version that fastens to the dash rail. Does this mean I would need to remove the original bracket or would it be ok to use both brackets? Thanks.
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 10-03-2023, 07:06 PM   #2
ModelA29
ModelA29's Avatar
Default Re: Steering Support Bracket Question
A friend installed one in his 28. He removed the bottom bracket from the original. He had to drill 1 hole if I remember correctly.
ModelA29 is offline   Reply With Quote
Old 10-03-2023, 07:39 PM   #3
Ray in La Mesa
You can leave the gas tank 1/2 in, just don't use the lower 1/2, might ad MORE stress to the gas tank.
Ray in La Mesa is offline   Reply With Quote
Old 10-03-2023, 07:51 PM   #4
31a
Take the bolts out and remove the bottom bracket and go on down the road.
31a is offline   Reply With Quote
Old 10-03-2023, 08:30 PM   #5
Gary WA
Gary WA's Avatar
Installed one on my 30 CCPU removed lower section of bracket and it bolted up with no extra hole drilling to dash area. Don't use both!
www.whidbeymodelaclub.com
Old 10-03-2023, 09:01 PM   #6
Steves46
Steves46's Avatar
Thanks all.
Old 10-03-2023, 09:47 PM   #7
Chris Haynes
Chris Haynes's Avatar
simply leave the rubber gasket out of the lower.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 10-04-2023, 05:59 AM   #8
Dino's A
Dino's A's Avatar
Best thing I ever did in a long time. When I was done with my install,
I watched as I pulled on the wheel to see if the new bracket totally
kept the steering column from touching the old half of the riveted bracket.
Nope, no touch. Like some already said, remove the lower half & rubber from
that and the upper, and it should be good. You will reuse the lower piece on the new bracket of course. Now when you climb in there, your not worried about those 80 year old rivets causing a leak down the road. The bracket comes a little rough, so I polished it smooth. Painted it the color of the dash so it blends right in.
1928 Roadster Pickup
1930 Tudor
1943 Ford WWII Jeep
1968 Taco Minibike
Member, Santa Anita Model A's
Arcadia Ca.
Dino's A is offline   Reply With Quote
Old 10-04-2023, 06:12 AM   #9
Kurt in NJ
Kurt in NJ's Avatar
50 years ago when I restored my car it came with leakage stains at the bracket, it got resoldered, still no leaks.
Old 10-04-2023, 06:36 AM   #10
Steves46
Steves46's Avatar
So I can use the original lower section half on the new bracket? That would be good and save a few dollars.
Old 10-04-2023, 08:36 AM   #11
Bob Bidonde
Bob Bidonde's Avatar
Here is the bracket change in my Victoria. I left the old bracket on the tank in place.
Bob Bidonde
Old 10-04-2023, 09:08 AM   #12
Gary WA
Gary WA's Avatar
I did remove lower bkt after install of new one. And i might have had to drill one hole been a long time. easy install tho.
Old 10-04-2023, 10:38 AM   #13
J Franklin
J Franklin's Avatar
A good topic and a good reminder not to use the steering wheel to help you into the front seat. I use the windshield knob if I need a boost.
