Old 08-09-2015, 09:28 PM   #1
Ed's Vickie
Ed's Vickie's Avatar
Default Door Hinge Hole Layout
Can anyone point me to were I can get the Hinge Screw Layout? Need to redrill. Thanks ED
Ed's Vickie is offline   Reply With Quote
Old 08-10-2015, 02:33 AM   #2
jw hash
jw hash's Avatar
Default Re: Door Hinge Hole Layout
for what body and what hinges
jw hash is offline   Reply With Quote
Old 08-10-2015, 10:19 AM   #3
Ed's Vickie
31 Early Vickie. Had to drill out the screws. Need layout (Dim.) for triangular pattern to retap all door hinges ED
Old 08-10-2015, 12:19 PM   #4
jw hash
jw hash's Avatar
Ed all Victoria`s used the same hinges as all the front doors on all the slant window bodies. The upper hinges that mounts on the cowl are the same on either side. that being said. if I have to weld the holes up and re-drill the hinges, I use one from the other side and put them back to back and mark the.
Old 08-10-2015, 11:19 PM   #5
Ed's Vickie
Thanks for the reply, I will try it . THANKS ED
