12-14-2016, 09:28 AM | #21 | |
Re: Where to buy water pumps
range sounds reasonable. You didn't mention if you are using stats or not. It seems you must have a pressure cap, Skips 3 lb valve or an over flow tank that is not vented. Or it could be you already lost a fair amount and the level dropped. Put a hose on the end of the over flow tube and the other end in an open VENTED container so you can see how much water you lost, start with a full, cold radiator. G.M.
www.fordcollector.com |
12-14-2016, 09:38 AM | #22 | |
12-14-2016, 10:00 AM | #23 |
I wouldn't leave the end of my driveway without having one of Skip Haney's rewound coils on my distributor, and I feel the same way about having a set of his water pumps on the engine. I have AAA coverage for more than 100 miles because I drive my old Ford all over this counrty, but who really wants to have a breakdown that requires being towed or loaded up on a roll back? I'm just very happy that we still have folks like Skip here in the USA supporting our hobby rather than having to rely solely on parts coming from unknown off shore sources.
12-15-2016, 03:22 AM | #24 | |
I'm guessing from your answer that your not talking about original Ford bearing type pumps, and your reference to not driving water pumps with bearings over 100 miles, that it's converted bushing type pumps with the little bearing that your talking about.? Martin. |
12-15-2016, 09:17 AM | #25 | |
than normal bearing failures in bearing type pumps. I would say even on modern cars water pumps are the part requiring the most replacements. The bearings in ALL 49 to 53 pumps except Lincoln all use the same shaft and bearing except the shaft lengths vary. These bearings consist of a roller and ball bearing combination. The roller bearing is the main bearing and the ball bearing with the grove in the shaft for the balls keep the shaft from moving. When rebuilding the various pumps Skip cuts the hard shafts to the required length with a cut off blade. G.M.
12-15-2016, 12:07 PM | #26 | |
12-15-2016, 02:04 PM | #27 |
Just to be clear, the early double sheave "truck" pump I'm on about isn't an 8BA pump, nor is it a 1949-1953 water pump. It's pre 1948 water pump that had a double row sealed bearing. It doesn't fit the 8BA style engine, only 59A and back to 1937. It was a "heavy duty" option, Big trucks, buses and that kinda stuff. These were/are fairly common over here (UK) as they were fitted on most Ford Pilots and Thames lorries. Think they were war time stock that subsequently got fitted on stuff after the war.
Martin. |
12-15-2016, 03:00 PM | #28 | |
12-15-2016, 05:13 PM | #29 | |
12-15-2016, 09:56 PM | #30 |
Sheesh... You guys are making me feel like I'll be driving around in a ticking time bomb with my new Bob Drake ball bearing pumps. They sounded great on his website. Anyone have experience with them. 59 ab style.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
12-15-2016, 10:00 PM | #31 |
Sheesh... You guys are making me feel like I'll be driving around in a ticking time bomb with my new Bob Drake ball bearing pumps. They sounded great on his website. I rarely buy new parts, but I was all out of used water pumps from my collection of cracked blocks so I decided to treat myself to some 'store bought' modern seal and ball bearing pumps. Anyone have experience with them? (59 ab style).
12-15-2016, 10:42 PM | #32 |
12-15-2016, 11:44 PM | #33 |
I believe most the early Fords had 22 or 22.5 quart capacity?? G.M.
12-16-2016, 03:23 AM | #34 | |
Sealed bearing water pumps have been used almost exclusively for 70 odd years, these cars are, believe it or not are used for distance over 100 miles without the need for a tow home. And like I've said, when Ford wanted a heavy duty version of the 59A type water pump for longevity in severe conditions and higher belt loads, they upgraded from a sort of oil feed bush pump to a sealed double row bearing pump. This I guess was successful, as they then used the sealed bearing on the later 8BA engines, discounting the very early 8BA pump that had an odd bearing setup. Martin. |
12-16-2016, 04:49 AM | #35 |
A lot of cars I`ve worked on had Drakes pumps, one of them for over 10 years, driven a lot on long trips around 600 miles long and never had problems, they are cheap and easy enough to change so why not try.
12-16-2016, 07:13 AM | #36 | |
12-16-2016, 11:28 AM | #37 |
Thank you gentlemen. Little bit of something on the gaskets or dry? I will antiseize the bolts.
12-16-2016, 03:02 PM | #38 | |
and a thin film of grease on both sides of the gaskets. DON"T use gasket cement, permatex or silicon. These sealants can plug the lubricant passages on some pump. The grease softens the gaskets a little, seals good and if you have to remove the pump the gaskets are still good for use again. G.M.
12-17-2016, 12:11 AM | #39 |
I have about 10000 miles over 6 years on Speedway 8BA truck pumps with no issues.
12-17-2016, 01:23 AM | #40 |
I vote Skip Haney located in FL!!!!
