Old 08-29-2013, 07:23 AM   #1
twilder
twilder's Avatar
Default Radius Ball Insert
Getting ready to repair radius ball. Old one has no springs nor spacers. Castle nuts ran all the way up snug. I know this isn't right, but the studs appear to be too short. Not long enough to add spacers and springs. Can these be adjusted? Are they just threaded up into the bell housing? Can old studs be replaced fairly easily?
twilder is offline   Reply With Quote
Old 08-29-2013, 07:47 AM   #2
gweilbaker
gweilbaker's Avatar
Default Re: Radius Ball Insert
They are bolts with special grooved heads that are held by a pin. The pin holds both and it is not easy job for someone with large fingers. You can see the pin above the ball assembly in the video--->https://www.youtube.com/watch?v=9CB2L_1xSD0
gweilbaker is offline   Reply With Quote
Old 08-29-2013, 08:01 AM   #3
Dave in MN
Dave in MN's Avatar
Replacement is possible by blocking the radius/front yoke down and then working through the hole in the bottom of the clutch housing (bell housing). Carefully bent pc's of wire can be used to insert the bolt through this opening and drop it in the hole. I also used a very thin piece of wire through the cotter hole in the bolt to pull the bolt through the actual hole it resides in...essentially a "fish" wire. It's a bit of effort but very easily done. Good luck...
Try to stay away from the rubber ball fix...the original style radius ball parts last much longer and provide for a better connection.
Good Day!
Dave in MN is offline   Reply With Quote
Old 08-29-2013, 10:40 AM   #4
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Go with what Dave says. The proper studs are longer than those with the rubber ball. Make sure you put a thin wire through the cotter holes and pull them down through the housing holes or theres a good chance they will slip out of your fingers and end up under the flywheel. If that happens the fix is to pull the engine and retrieve the bolts. (Arrgh! it happened to me !)
Barry B./ Ma. is offline   Reply With Quote
