Old 06-06-2015, 10:41 PM   #1
Neil Mylar LakewoodCA
Neil Mylar LakewoodCA's Avatar
Default Low mileage popout (sticks sometimes)- Should I rebuild?
My Sept 28 Tudor still has the original popout (less than 60,000 miles).
It usually works fine, but occasionally it sticks and doesn't pop out.
Is there anything I can do, to assure that it pops out all the time?
Or should I just have it rebuilt?
My popout has the thick bracket that bolts to one of the head studs. Will that bracket fit through the junction box opening and up through the gas tank wiring chamber?
It looks like I will at least have to remove some of the wiring to make it fit through the junction box opening.
Thanks, Neil
Neil Mylar LakewoodCA is offline   Reply With Quote
Old 06-07-2015, 01:12 AM   #2
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Low mileage popout (sticks sometimes)- Should I rebuild?
The housings are made of "pot metal" or rather die cast zinc. Be careful of what you use to lube it as it may cause damage to the housing.
Old 06-07-2015, 01:21 AM   #3
Mike,
Thank you for the advice.
Could I just squirt some graffite power on the pop out part?
Neil
Old 06-07-2015, 01:27 AM   #4
Mike V. Florida
That should work just fine. little goes a long way.
Old 06-07-2015, 07:43 AM   #5
mhsprecher
mhsprecher's Avatar
Dick Crabtree in South Dakota services them. Quick service, reasonable price. Good guy to deal with. Look him up on forum.
mhsprecher is offline   Reply With Quote
Old 06-07-2015, 08:39 AM   #6
BudP
BudP's Avatar
My advice is to pull it out and get it fixed. It will not get any better. Mine got stuck when I was at a shopping center on a rainy morning and would not pop out. I strongly endorse doing business with Dick Crabtree: he's a nice man who knows what he is doing and charges reasonable prices. And, yes, you can get that thick holddown through the firewall: remove all the wires first and be patient.
BudP is offline   Reply With Quote
Old 06-07-2015, 09:48 AM   #7
Does anyone have a phone number or email address for Dick Crabtree?
Old 06-07-2015, 09:51 AM   #8
Mitch//pa
top of the page under plucks web site sticky...
Old 06-07-2015, 10:13 AM   #9
mhsprecher
mhsprecher's Avatar
You can disassemble and just send the cylinder to him. That makes it much easier.
Old 06-07-2015, 11:13 AM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
DO NOT use WD-40 on the potmetal. I would give it a shot of Loc-Ease (sp?). I couldn't find that product at the time, but my 99 Olds column switch was getting very stiff this past winter, and a squirt of powdered graphite fixed it right up. My tumblers were stiff for the key to push up.
If the Loc-Ease doesn't help, then send it to one of the lock guys.
Old 06-07-2015, 07:31 PM   #11
ODFever
ODFever's Avatar
I had problems with my pop out. When I turned the key, the pop out popped out but the car wouldn't start. I replaced it with a keyed switch from Mike's I haven't had a problem since installing the new switch.
ODFever
1930 Ford Model A Town Sedan "Alyssa"
ODFever is offline   Reply With Quote
