05-25-2015, 11:53 AM | #1 |
Fram CH-15PL
Is this a correct oil filter for a 59ab canister? Found one in a parts box in my shop's attic. I have the bare filter but no rubber or cork parts except I do have a good top cover rubber ring. There are some rubber washers etc left over from my felpro set. Hoping to do an initial fire up within the hour. If this filter won't work, I may go filterless at first.
05-25-2015, 01:14 PM | #2 |
Re: Fram CH-15PL
Fram is C4. Motor Craft is FL25, Wix, 51006, Purolator P34.
05-25-2015, 04:39 PM | #3 |
Re: Fram CH-15PL
