06-11-2013, 09:52 PM | #1 |
carriage bolts
Does any one know where I can get 3/8-24x2 1/4in. carriage bolts?. Or does most restorers both Pro and Armatures used 3/8-16x2 1/2 when mounting the body to the frame. Most cars need 4. Richard
06-11-2013, 10:02 PM | #2 |
Re: carriage bolts
Man I wish I knew too. The fine-thread is the kicker!! I am resorting to making them on a lathe using all-thread and roundstock, ....to the tune of about 30 minutes time in each one!!
06-11-2013, 10:35 PM | #3 |
Re: carriage bolts
How big is the demand for these? There is a local bolt company here that will do custom runs. If the quantity would justify the cost (to you), they would make to order. Even if you only needed one, they'd do it, but of course, the cost would be up there.
06-11-2013, 11:01 PM | #4 |
Re: carriage bolts
Building a fine point car? If not, most of us just use the bolts sold by the parts venders. If your doing fine point, have you looked at www.mantiques.comThey have more original nuts and bolts than I've seen anywhere else. You might also check www.fordbolts.com he has some strange stuff (the K. R. Wilson tool paint is fantastic)
DMAFC |
06-12-2013, 12:49 AM | #5 |
Re: carriage bolts
Maybe we should see what kind of demand there might out in ford land for them. 700rpm might be able to put something together in Portland. I could used 8 if the price was right. Is there anybody else that might be able to use some 3/8-24x21/2 in carriage bolts. Richard
06-12-2013, 01:02 AM | #6 |
Re: carriage bolts
06-12-2013, 01:24 AM | #7 |
Re: carriage bolts
I could use a dozen here. Likely there is a minumum order quanity of over 1000 to justify the setup and tooling costs. Rod
06-12-2013, 09:11 AM | #8 |
Re: carriage bolts
Roy Nasewicz (spelling) specializes in bolts, fasteners for fords, lots of people on the EV8 forum use him. Might be worth it to contact him.
Paul in CT |
06-12-2013, 10:02 AM | #9 |
Re: carriage bolts
There is a company in Escondido, CA called Restoration Supply, I haven't asked them about those bolts but it may be worth a phone call to them?
06-12-2013, 10:35 AM | #10 | |
Re: carriage bolts
Right now I am using round bar stock and shaping the head on the lathe, then drilling & threading it, parting it from the stock, followed by cutting the appropriate length of All-thread and screwing it up into the new head. Next we TIG weld the top of the All-thread and metalfinish the end to match the contour of the head. If I need the square tang under the head, I use square bar stock that has been drilled & threaded. I part it at ¼" inch and screw it up onto the bolt threads. Loc-tite secures the square shank onto the threads. As you can probably tell, it takes an average of 30 minutes each for me to do it our way, so someone taking the time to make a batch of correct looking ones sure would be a plus. . |
06-12-2013, 11:32 AM | #11 |
Re: carriage bolts
Hi,
I hope this is what your talking about. The carriage bolt that is used in the cowl subfloor area. Note fine tread and the thin dome head. At swaps I am always looking for tin cans with original A bolts etc. Jim |
06-12-2013, 11:35 AM | #12 | |
Re: carriage bolts
Yep, that's it Jim. Thanks!! Your idea about scrounging in tin cans is great, ...except I need to find enough to do 6-8 cars a year! Not sure I have enough time to search thru that many tin cans!! |
06-12-2013, 01:22 PM | #13 |
Re: carriage bolts
There you go Roy. Read Brent in 10-uh-c thread he has several different sizes he could use. Others have expressed interest in the 1/8-24x2 1/4 in. Maybe worth checking to see what it would be worth to make maybe 100 of them. Thank you Richard
06-12-2013, 01:33 PM | #14 |
Re: carriage bolts
Hi! Jim Yep! That be the one I have 1 that I could save. I would put the Modern bolts in but it just would not feel right and it properly bug me forever. Ford put the in for a reason and like Brent was going make my own.
06-13-2013, 07:35 AM | #15 | |
Re: carriage bolts
"All the correct nuts, bolts, and washers necessary to attach body to the frame. All hardware plated to original Ford Specifications. These kits contain exact reproductions of the hardware as shown in the MARC/MAFCA, DeAngelis-Frances charts."
06-13-2013, 08:46 AM | #16 |
Re: carriage bolts
Havy you tried contacting some of the larger impliment companies as Caterpiller, John Deere, Case etc to see just what kind of bolts/lock washers they have?
I know one time I had to use a special Model A bolt (fine thread) to fix a John Deer Harvester just so I could keep harvesting! Might be worth your while to email or call these companies just to see instead of beating our heads against the wall. Pluck Last edited by Steve Plucker; 06-13-2013 at 09:01 AM. |
06-13-2013, 12:27 PM | #17 | |
Re: carriage bolts
07-11-2013, 03:47 PM | #18 |
Re: carriage bolts
Richard/CA sent me a sample of the bolt in question and I took it to a former client of mine, Portland Bolt, to see if they could make some. They are a big outfit and do specialty runs, but they said they couldn't do this one for a couple reasons: They are hotheaders, and this bolt is too small for them; it's too short for their threading machines; carriage bolts are made from wire feeders, which is why modern heads are the size they are, and which Portland Bolt doesn't do. So a big strikeout here.
07-11-2013, 08:50 PM | #19 |
Re: carriage bolts
Nope just strike one Ray. I am retired and really have a lot of time to look some more. I will just keep plugging along maybe I'll get lucky. But thank you for trying. Richard
07-11-2013, 09:39 PM | #20 |
Re: carriage bolts
Does Roy sell the Robertson, square head, screws as well? I have a Canadian built A and would like to replace a couple rusty screws.
