11-21-2022, 01:45 AM | #1 |
1928 Tudor parts
City:
Orange county
State:
Ca.
Looking for a few 1928 parts,
*cast front seat hinges (upper and lower) *Seat bar PM me with what you have...Thanks. Here's the '28 seat risers, notice the casting line on the side, the way the area is around the flat top and the angle around the bottom flat area. Should have an "M" cast in them or even a "Ford" script also. Last edited by 1oldtimer; 12-05-2022 at 01:00 AM. |
11-21-2022, 01:48 AM | #2 |
Re: 1928 Tudor parts
Here's the 29-31 or 30-31 not 100% when these started and the other ended. I already have this type.
Has a distinct ring at the base above threads and the head is a machined flat spot. Last edited by 1oldtimer; 11-21-2022 at 01:59 AM. |
11-21-2022, 01:50 AM | #3 |
Here's the '28 cast upper part of the seat hinge that is attached to the bottom of the seat. It's cast and has a stud that goes into the seat.
11-21-2022, 01:54 AM | #4 |
Lastly the seat bar. I think 30-31 had 2 cups, maybe 29 also??? under the seat as a stop for the floor. The 28 had a bar...
12-05-2022, 01:01 AM | #5 |
Bump.
12-30-2022, 10:53 PM | #6 |
02-26-2023, 04:37 AM | #7 |
I need 1 more cast seat hinge and at least 1 seat bar.
05-23-2023, 12:33 AM | #8 |
Bump
07-27-2023, 12:50 AM | #9 |
Back up
08-18-2023, 02:46 PM | #10 |
Thanks to jw hash all I need now is the seat bar in post #4.
09-15-2023, 08:18 PM | #11 |
Seat Bar ?????
11-18-2023, 12:59 AM | #12 |
Bump for a seat bar.
01-13-2024, 03:37 AM | #13 |
I have everything on my list above EXCEPT a seat bar (pictured in the post above). I need at least one but will take 2 if you have them.
Need the seat bar ONLY, can't edit the older posts. Thanks. Last edited by 1oldtimer; 01-14-2024 at 02:05 AM. |
