06-17-2016, 09:20 AM | #1 |
triple carb setup
I am trying to help a friend who is building an 8BA and looking for a way to handle the generator and top radiator hoses on his triple carb setup. The front carb requires offsetting the generator but then is in the way of a radiator hose. Is a 6 volt alternator much shorter than a generator? Any pictures?
Thanks John |
06-17-2016, 10:37 AM | #2 | |
Re: triple carb setup
John: Offy and others sell different water outlets that put the hose coming off the head at different angles. That should do it. If you buddy doesn't want to spend money on new water outlets, you can always use the universal-type hose that allows you bend it any way you need. New outlets are a cleaner way to do it, but it's up to your buddy. Good luck, Tim |
06-17-2016, 04:38 PM | #3 |
The best option, and perhaps your friend won't agree, the best option is to lose the third carburetor and go with just two carbs. That third carb won't make a big difference in performance. Two carb set up eliminates the generator/radiator hose problem and is plenty of carburetion for a street flathead.
06-17-2016, 07:24 PM | #4 | |
John |
06-17-2016, 08:18 PM | #5 |
An alternator will absolutely work with an Offy three carb manifold.
There's about 3/16" between the back of the alternator and the front of the carb.
RIP Tyler... My Son, Helper & Best Friend. Feb '78 to Father's Day '10. www.97-express.com ~ [email protected] |
06-17-2016, 11:21 PM | #6 |
06-18-2016, 05:49 AM | #7 |
Offset water neck/thermostat housings are your real best bet.
Keep the three carbs, keep the generator, keep it all nice and proper looking. You should be able to look through Google images for triple carb 8BA pictures, see what others have done to keep it all right. Martin. |
06-18-2016, 05:59 AM | #8 |
06-18-2016, 09:18 AM | #9 |
We use a Denso alternator on a Edelbrock three carb intake. These are available from Amazon. Not sure if they make a 6V unit. WE made our own mounting bracket and mounts in front of the first carb with aprox 1/2 clearance. These run less than a 100 bucks.
