12-25-2016, 01:55 AM | #1 |
6 Volt Red LED Positive Ground Bulbs
I just came across these 6 volt positive ground red bulbs, in case someone wants to paly around with making turn signals or a third brake light. They do have an odd socket though.
http://www.ebay.com/itm/4X-6V-6VOLT-...dYGaJ-&vxp=mtr |
12-25-2016, 04:37 AM | #2 |
Re: 6 Volt Red LED Positive Ground Bulbs
This even has a screw terminal, not some short 24 awg lead on it.
http://www.ebay.com/itm/NEW-281-282-...-/301662805918 |
12-25-2016, 09:43 AM | #3 |
Thanks Bruce.
The bulbs I listed are then smaller than I thought, so they won't work for what I had in mind. |
12-25-2016, 10:13 AM | #4 |
German cars of the 50s, 60s had that base for instrument cluster bulbs, very low wattages----not many of the cars with that base were + ground though
12-25-2016, 02:12 PM | #5 |
I'm going to order some of these for blinkers in my headlights, i'll let you know if they are any good. Just a warning if ordering anything direct from china it takes ages to get to you, in Australia anyway. http://www.ebay.com.au/itm/302118929...%3AMEBIDX%3AIT
12-25-2016, 02:23 PM | #6 |
https://www.superbrightleds.com/cat/...al,6,100,8619: Merry Christmas!
"If you can't fix it with a hammer, you've got an electrical problem" |
12-25-2016, 02:31 PM | #7 |
I can't find much on the BA7 base, but, I think its 10mm rather than 5/8"[19mm] like the BA15 that we need.
This is a BA15S #1056 in 6v LED. Seems like it should work for us but I don't know if its polarity sensitive. https://www.superbrightleds.com/cat/...al,6,100,4204: Last edited by Patrick L.; 12-25-2016 at 02:38 PM. |
12-25-2016, 06:46 PM | #8 | |
