10-16-2022, 07:01 PM | #1 |
1932 Steering - Ratio Questions???
My buddy and I were looking at some NOS steering sectors that he has - and we compared them to his 32 sector. Many of his parts were NOS stuff that his Uncle collected years ago - but there are no tags or part numbers to help with identification on these.
His original has no markings for ratio, but the NOS ones both have a '15' on them. We also looked at one that had a 13 on it. In doing side-by-side comparisons, it appears his matches the ones with '15' on them. Was wondering what ratios were used in 32 . . . and if a '15' would be a correct version? His original sector has a few wear spots, so we'll probably swap in a NOS one. Any information is greatly appreciated! B&S |
10-16-2022, 07:32 PM | #2 |
Re: 1932 Steering - Ratio Questions???
1932 original ratio is 13:1. I believe 1933-34 ratio was 15:1. I change all my
1932 steering boxes to 15:1 You need to change both worm and sector when changing the ratio. |
10-17-2022, 07:00 AM | #3 | |
Thanks so much! |
10-17-2022, 07:11 AM | #4 |
Dale, Sent you a PM
10-17-2022, 08:14 AM | #5 |
The first 5,000 '33s also had 13 to 1 ratio steering gears.
10-17-2022, 09:00 AM | #6 |
10-17-2022, 10:42 AM | #7 |
In a similar spot as Dale. How much of a noticeable difference does the 15 to 1 ratio make over the '32 13 to 1?
10-17-2022, 01:05 PM | #8 |
Not worth the effort to find the worm gear and then change it, in my opinion. The sector gear is the easy part.
10-24-2022, 08:38 PM | #9 |
3rd Gen auto sells 15:1 worm and sector gears. I just bought a set from him to convert my 32 sedan to 15:1. From what I have heard, they are good quality.
Matt
1932 2 door sedan/ Merc Flathead 1932 5W 1932 Roadster/ SCoT Flathead 1932 Roadster Cadillac power |
10-25-2022, 07:59 AM | #10 |
Deuce Lover gave me a tip to purchase one - it is on the way. I will report back as to what I find with the quality and fitment to an original 32 box. Thanks gang!
