11-06-2021, 01:30 PM | #1 |
lt steering arm/drag link question
1928
i have the first style steering arms on my car. (ford did a change up) did the drag link stay the same or was it shorter to compensate for this change? basically , were there 2 different length of drag links used on the model A? thanks
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
11-06-2021, 02:09 PM | #2 |
Re: lt steering arm/drag link question
They changed the arm that connects to the tie rod, the part than connects
to the drag link stayed the same. |
11-06-2021, 06:11 PM | #3 | |
im looking for the reason and the first thing i noticed was the steering arm is the old style. thanks
11-06-2021, 11:20 PM | #4 |
I think this article will answer your question. https://modestoareamodelaclub.org/lopsided-steering
11-07-2021, 09:30 AM | #5 | |
with the toe-in set correctly it would seam that there is no way to change that difference on the model A unless the distance from the left steering arm to the pitman arm is modified. maybe that is why ford changed the steering arm design, don't know. i think with the old style steering arm on there the difference is more prominent.
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." Last edited by old ugly; 11-07-2021 at 09:36 AM. |
