01-01-1970, 12:00 AM | #1 |
Guest
Posts: n/a
Dual exhaust 54 Ford Y block
Hey guys - I still need help - there must be a way to put duals on this thing. I had one when I was a kid, but I don't remember how I did it and that was before all the pipe benders and stuff. Olease help. It is a 1954 Ford Victoria, 292 V-8, Std. 3 spd column, w/OD. Thanks, Hardy <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #2 |
Guest
Posts: n/a
Re: Dual exhaust 54 Ford Y block
Simple--find some 1955 up set of Y block manifolds for Dual Exhaust. Many came from the factory with duals, the 312 was standard with duals. Then hopefully your local muffler shop has a good pipe bender there and youre set <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #3 |
Guest
Posts: n/a
Didnt you bother reading down to my prior reply? Info still valid. <table><tr><td><font face="arial"> |
01-01-1970, 12:00 AM | #4 |
Guest
Posts: n/a
55 56 57 292 or 312 Manifolds will work.left side T-Bird will not because the firewall curve is diffrent. <table><tr><td><font face="arial"> |
