01-16-2021, 02:02 AM | #1 |
U-Joint rebuild
Any body out there who knows how to get the spring keepers out to take a u-joint apart.
01-16-2021, 07:52 AM | #2 |
Re: U-Joint rebuild
Can you post a picture of what you have?
Sent from my iPhone using Tapatalk |
01-16-2021, 10:01 AM | #3 |
Re: U-Joint rebuild
I use a dremel tool cutoff wheel to cut the keeper in half. the new kit comes with new keepers.
01-16-2021, 01:14 PM | #4 |
Re: U-Joint rebuild
Thanks. I was trying to save the keepers, but that is a good idea
01-16-2021, 01:11 PM | #5 |
Re: U-Joint rebuild
You have to release the tension from the spring. Mount the U-joint securely in a vice and place a chisel over the center of the spring clip and give it a solid rap with a hammer. The spring clip should relax a bit, allowing you to prise it out with a sharp screwdriver or pull it out with pliers.
01-16-2021, 01:42 PM | #6 |
Re: U-Joint rebuild
Bob Bidonde |
01-16-2021, 07:55 PM | #7 |
Re: U-Joint rebuild
what is the best way to get the c clips in ?
01-16-2021, 08:01 PM | #8 |
Re: U-Joint rebuild
I use a sharp scribe and work it in between the clip and the cup grove.
01-17-2021, 08:06 AM | #9 |
Re: U-Joint rebuild
I tap them in with a 4 ounce ball peen hammer.
Bob Bidonde |
