10-10-2017, 11:20 PM | #1 |
Steering wheel play
So is there a way to test a steering column without disassembling it for excess play?
10-11-2017, 04:39 AM | #2 |
Re: Steering wheel play
Sure, fabricate a mount that replicates the holes in the frame yet with the column laying horizontal, and then clamp it in your vise. Use an old worn pitman arm and weld on a 12" extension for additional leverage, ...and use the steering wheel and the modified pitman arm simultaneously to check the backlash/adjustments.
10-11-2017, 07:30 AM | #3 |
I don't believe there is a short way here. Steering is "important". If your concerned about something, take it apart and check or fix it. Than there will be no question as to what your dealing with.
Be sure, be safe. Enjoy. |
10-11-2017, 07:35 AM | #4 |
Steve 1930 Model A Roadster |
