10-29-2019, 12:25 PM | #1 |
radiator question
how far should radiator be from water pump shaft
10-29-2019, 05:11 PM | #2 |
Re: radiator question
As long as the fan clears the radiator your good,off hand it is probably several inches.
10-30-2019, 09:30 AM | #3 |
The position of the radiator is adjustable, and there are variations in the core thickness of reproduction radiators, so the clearance to the pump shaft will be a range of dimensions. I just measured the clearance on my 1931 Victoria which has a Walker radiator, and it has 0.75".
Bob Bidonde |
10-30-2019, 06:30 PM | #4 |
I'm guessing, but i presume you don't have much choice as the radiator supports dictate how wide the bonnet gap will be???
10-31-2019, 04:00 AM | #5 |
1" on my 1928 with solid motor mount and original pump and radiator.
10-31-2019, 11:48 AM | #6 |
10-31-2019, 04:31 PM | #7 |
my new radiator cracked below the return pipe. I have the new type engine mounts, float a motor and they allow more movement and I reckon that allowed the engine to move forward just a smidgeon when the motor car accelerated. Thus a small movement. Well that's the most probable reason.
Give a margin. And those mounts are great. No more tingling hands.
I know many things, But I don't know everything, Sometimes I forget things. And there are times when I have a long memory. |
11-03-2019, 08:29 PM | #8 |
What aluminum radiator did you choose?
My radiator is leaking when my truck is warm. I'm looking for a replacement. Thanks! |
