Old 06-04-2020, 07:36 PM   #1
Old Redneck
Old Redneck's Avatar
Send a message via AIM to Old Redneck Send a message via Yahoo to Old Redneck
Default Air Vent left of Steering Column ??
I got the cable for the Air Vent on the left side of the Steering Column BUT I have no idea where it goes. Can someone help me on this.I have got to get me a shop manual for this bird.
Old Redneck is offline   Reply With Quote
Old 06-04-2020, 07:48 PM   #2
paul2748
paul2748's Avatar
Default Re: Air Vent left of Steering Column ??
It ends up connected to a flapper valve on the fresh air duct in the engine compartment. It routed through the rubber biscuit that holds the wires that go through the firewall.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-04-2020, 08:10 PM   #3
miker98038
miker98038's Avatar
Paul's correct. It's a bit hidden behind the battery, and under the lip of the hood, so it's not obvious till you look. There's a bracket behind the battery that holds the end of the jacket, the flapper is 4-5" in front of it on my 55
miker98038 is online now   Reply With Quote
Old 06-04-2020, 09:59 PM   #4
Daves55Sedan
Daves55Sedan's Avatar
When you locate the air duct (under the fender) where the bellcrank is for the damper, there should be a bracket sticking up on that duct which has a little hold down clip, held on to the bracket with a typical hex head lag-screw like they used on all the other heater sheet metal parts. If the little clip and screw are missing, let me know bu PM, and I will look in the garage, I think I have several of those with the screws.
Old 06-04-2020, 10:02 PM   #5
40cpe
40cpe's Avatar
I'm no T-bird expert but I thought the fresh air was the doors on the fender exterior on a '56. Is there a fresh air duct from the front as on a sedan?
Old 06-04-2020, 11:01 PM   #6
miker98038
miker98038's Avatar
IIRC, the side vent behind the wheel has a grill in the kick panel, and a separate knob. The dash knob runs the front vent (like my 55) similar to the passenger car. Been a long time.
Old 06-04-2020, 11:02 PM   #7
dmsfrr
dmsfrr's Avatar
Originally Posted by 40cpe View Post
. . . Is there a fresh air duct from the front as on a sedan?
Yes, there are a pair of fresh air scoops just behind the grille on each side. (photo 1)
The ductwork goes up over the front tires and comes out above each kick-panel on a '55, '56 & '57 T-Bird. They are just above the fender vent chrome grilles in the kick-panels of a '56/'57 T-Bird.
The fresh air vent cables & knobs on the dashboard control the on/off flapper valves. One is just outboard of the battery, the other is outboard of and slightly behind the heater fan motor. (photo 2)
Old 06-05-2020, 06:37 AM   #8
Old Redneck
Thank you fellows. I will install today. Thanks again
Old 06-05-2020, 07:33 AM   #9
Hot Rod Reverend
Hot Rod Reverend's Avatar
This will help you --
https://www.hotrodreverend.com/post/...tic-should-own
these things are a gold mine
Lancaster, California
Visit hotrodreverend.com to view hundreds of pictures and videos of the build of the 1955 Ford Club Sedan!
Hot Rod Reverend is offline   Reply With Quote
