Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 06-16-2021, 12:08 AM   #1
waynerd45
Default 1935 Ford headlight mount
I'm repainting my '35 ford sedan. When I pulled the headlight buckets there was 6 large flat washers and a lock washer on the mounting bolt. Is this correct ? I thought that it should have a heavy spring. If it uses a spring, where can i get one. Thanks for the help.
waynerd45 is offline   Reply With Quote
Old 06-16-2021, 07:04 PM   #2
redmodelt
redmodelt's Avatar
Default Re: 1935 Ford headlight mount
You need to ask on the Early V8 forum. This section is for questions about the site not car. Few look here and even fewer reply.
