Old 12-13-2017, 02:58 PM   #1
johnbuckley
johnbuckley's Avatar
Default Multidisc clutch housing ID?
Did the gearbox with the fins (as shown with bit of wood pointing in photo) only take the multidisc clutch?? ( And similar the non fin box only have the singe plate?) ... . If so is this an easier way of identifying a multidisc vs a single plate car without taking the carpet /floor board up
johnbuckley is offline   Reply With Quote
Old 12-13-2017, 03:12 PM   #2
F.M.
Default Re: Multidisc clutch housing ID?
The U.S. built Cars & Trucks with the Early Assy. did not have you call the "Fins".. Yes the pedal shaft is smaller in dia.. And real Early the pedals were Smooth..
F.M. is offline   Reply With Quote
Old 12-13-2017, 04:15 PM   #3
Purdy Swoft
Purdy Swoft's Avatar
I've been told that the multiple disc cars used a different gear shift knob so that a person could tell without removing the floor boards or seeing the pedal shaft diameter . Sorry , I don't have a picture of the early knob but it isn't a round ball like the more common later knob but is flatter .
Old 12-13-2017, 04:38 PM   #4
Fullraceflathead
Fullraceflathead's Avatar
I believe the cover is wider that tall on the multi disc bell housing.
The Standard Single Clutch Disc Bell housing cover is taller than it is wide.
"If I asked people what they wanted they would have said faster horses."
-Henry Ford
"Primitive technology is not a design flaw"
1928 Ford Model A Roadster Pickup
1930 Gordon Smith Air Compressor
1941 Willy's Pickup
1960 Thunderbird-For Sale
1964 Buick Riviera 2x4 425
1965 Pontiac GTO, 455 Super Duty
2004 Dodge Ram SRT-10, V-10 Viper
1977 Charger Jet Boat,460 Ford,Jacuzzi Jet
Front Engine Nostalgia Dragster,Supercharged 296 "Fullrace Flathead" Ford
Engine Build up on DVD ask
Fullraceflathead is offline   Reply With Quote
Old 12-13-2017, 06:25 PM   #5
quickchange
quickchange's Avatar
Easy check , the tin inspection plate for thrust bearing is different shape , has a bend in it while later is flat piece, many other differences, please send us rain, ??
quickchange is offline   Reply With Quote
Old 12-14-2017, 05:05 AM   #6
johnbuckley
Yes the inspection covers are a different shape but to access that involves lifting carpets and floorboard panel etc. I was wondering if a quick peek underneath at the fins would establish multi vs single when viewing a car.
"The U.S. built Cars & Trucks with the Early Assy. did not have ... the "Fins". So when and on what did these fins/ribs appear ?
Old 12-14-2017, 03:15 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Multidisc clutch and brake pedals shaft is 3/4" on multiplate, but 7/8" on single plate clutch.
Old 12-14-2017, 03:32 PM   #8
Tom Endy
Tom Endy's Avatar
Quite often the early pedal shafts in the multi-clutch bell housings have been replaced with a later pedal shaft. This is done by machining the end of the shaft to fit into the bell housing. The purpose being to use the later pedals that have bushings.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 12-15-2017, 04:04 AM   #9
juke joint johnny
juke joint johnny's Avatar
John I have a multi-plate bell housing it does not have the fins on it.
I also have the clutch and flywheel and a 1/2 " drive starter if you need them
John Cochran
juke joint johnny is offline   Reply With Quote
Old 12-15-2017, 04:49 AM   #10
john charlton
john charlton's Avatar
On a RHD multidisc bell housing the pedals are round and smooth faced that is no horizontal grooves. So it is easy at a glance to tell what you have .It has no fins . I think the shaft dia is heavier than the LHD bell housing . The single disc RHD bell housing has a 1" dia shaft not 7/8" as LHD . Many RHD restorers have found this out when they ordered a pedal bush set from a USA parts vendor .( Belcher Engineering do these). I think Ford beefed up the shaft because most RHD vehicles would be destined for rough roads and a hardy life in Africa ,India ,Argentina ,Uruguay and Down Under etc etc . I cant measure my multidisc pedal shaft dia as the pedals are on maybe the honourable John Cochran can measure his and let us know . Some Canadian export RHD multidisc cars had oval pedals but I think they were smooth also .
John in very cold bleak winter Suffolk County England
john charlton is offline   Reply With Quote
Old 12-15-2017, 06:24 AM   #11
johnbuckley
Thank you everyone for the expert input. I was trying to establish if there any other way of ascertaining for sure if a car had multiplate or single plate other than looking at the inspection cover. And I think the answer... " No, because of the various changes and varieties that were introduced by Ford plants during the A production life and modifications to individual cars over the past 80+ years!"
Old 12-15-2017, 03:38 PM   #12
john charlton
Acording to the English and USA parts book there were no production changes to both types of clutch housing LHD or RHD . Some people maybe did not like smooth pedals so fitted the later ribbed style by modifying the pedal shaft (as a previous post) or fitting oversize bushes and the mushroom shifter knob can also be changed so looking in the car cannot give a truly one hundred percent identification . However the multi disc had no fins and the single plate did, no doubt about it . So with a suitable pair of gloves you can open the bonnet/hood and on the opposite side to steering column reach around the flywheel housing and you can feel if you have fins or not . You do need gloves because its real greasy down there . If you do not want to go the sticky route jack up the front and take a look or a mirror on a stick !!!
John in sunny tommorow they say Suffolk County England .
Old 12-16-2017, 10:35 AM   #13
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
The Girls shy away, when you have a "MIRROR ON A STICK"---LOL
"THE ASSISTANT GURU OF STUFF"
