07-16-2018, 07:15 PM | #1 |
64 Galaxy remove constant voltage regulator
OK I've been bent up side down under the dash trying to remove the instrument cluster so I can replace the voltage regulator so my fuel and temperature gauges will work . I've tried everything I can't get to the nuts for the retaining clips that hold the wire harness in place. what's the secret
07-16-2018, 08:00 PM | #2 |
Re: 64 Galaxy remove constant voltage regulator
OK guys I got the wire harness retaining clips unbolted and the answer is get your wife to do it. This is going to cost me dearly and well worth it
07-16-2018, 08:16 PM | #3 |
Good for you. I hope payback is not too bad. A suggestion for the future - if dong any extensive work under the dash remove the font seat so you can lay flat on your back.
07-17-2018, 09:06 AM | #4 |
Paul has the right answer a word of caution if you are of the age you need a nap at times do it before attempting this job
07-17-2018, 10:21 AM | #5 |
