Old 12-29-2017, 02:44 PM   #1
louisb
louisb's Avatar
Default Transmission Case Question
Hi All,
I wanted to get some input on this transmission rear thrust surface. With this amount of wear is this case still good or is it yard art? I am unclear from the description in Vanpelt’s book. This is a 39 style toploader case. I am hoping I am not going to have to find another case.
Thanks,
—louis
File Type: jpg A4704FCE-70AD-47C5-9F03-FCECBBF3C55F.jpg (91.2 KB, 150 views)
louisb is offline   Reply With Quote
Old 12-29-2017, 02:52 PM   #2
Capt Kirk
Capt Kirk's Avatar
Default Re: Transmission Case Question
I believe there was a thread on here not too long ago about machining this surface and how to bring clearances back. I'm not sure what kind of search would find that thread though.
35 Ford Cabriolet
56 Chevy Pickup
63 VW Bug
Empty wallet
Capt Kirk is offline   Reply With Quote
Old 12-29-2017, 03:16 PM   #3
V8COOPMAN
V8COOPMAN's Avatar
I believe Mart and Charlie NY were talking about that one, FWIW! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 12-29-2017, 03:24 PM   #4
louisb
louisb's Avatar
I think Vanpelt mentions this in his book but I don’t have a lathe/mill so I would have to send it to someone.
Thanks,
—louis
Old 12-29-2017, 03:41 PM   #5
rotorwrench
rotorwrench's Avatar
It can be surfaced with a special reverse counter bore tool but that's some special stuff for one that large. A person with a lathe and some tooling skills could also make a lapping tool from a piece of correct diameter shaft stock and a disk cut with a bore to fit the shaft and the correct diameter to fit against the thrust face. That would take a while to lap it back flat though. Mac VP recommends either reconditioning or replacement. When you put the thrust washers, cluster, & shaft assembly back in, you don't want a lot of gap to reshim there with .005" to .017" recommended end play clearance.
Old 12-29-2017, 03:58 PM   #6
louisb
louisb's Avatar
Yeah I think I am looking at finding a better case.
Thanks,
—louis
Old 12-29-2017, 05:11 PM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
This is the thread that Mart posted about machining his transmission case with the same or similar problem.
https://www.fordbarn.com/forum/showt...nsmission+case
John
Old 12-29-2017, 05:49 PM   #8
louisb
louisb's Avatar
Wow, that is impressiveand way beyond my skill level. Thanks for the link.
—louis
Old 12-29-2017, 05:56 PM   #9
Charlie ny
Lou,
Check your PM's
Charlie ny
Charlie ny is offline   Reply With Quote
Old 12-29-2017, 06:07 PM   #10
Russ/40
Russ/40's Avatar
Thanks,
—louis
That can be remedied with some persistence on your part. Cut a piece of flat plate into a circle about the size of the thrust surface. It should be at least 1/4" thick. Use the piece with some valve grinding compound and scrub the thrust surface across the surface in an orbital manner. Not a spin on the surface but across the surface in all directions. When you get it cleaned up, USE THE OLD REAR THRUST WASHER ground to the necessary thickness needed to add to the new thrust washer for the proper end play. I have done this, and although tedious, it works real well, and you can get the exact clearances you want.
Russ/40 is offline   Reply With Quote
Old 12-29-2017, 06:10 PM   #11
rotorwrench
One of these would likely work with a 3/4 mandrel but a person would have to plan on doing a few for the price.
https://www.mscdirect.com/browse/tn/...110+4288230198
Old 12-29-2017, 10:38 PM   #12
KiWinUS
KiWinUS's Avatar
Hi All,
Thanks,
—louis
That’s what happens when you put a “Henweigh” in your transmission 😁
KiWinUS is online now   Reply With Quote
Old 12-29-2017, 10:45 PM   #13
JRHASZARD
JRHASZARD's Avatar
Or a potfer
JRHASZARD is offline   Reply With Quote
Old 12-29-2017, 10:55 PM   #14
louisb
louisb's Avatar
—louis
Old 12-29-2017, 11:14 PM   #15
cas3
Louis, you will want new thrust washers any way, so buy some and install the cluster gear and measure the end play. then, you know what you have for wear. the surface you show is not gouged up that bad to me, id check it out before giving up
Old 12-30-2017, 10:46 AM   #16
rotorwrench
The thrust load is strong enough that the big soft thrust washer would wear into those grooves pretty quick. The clearance would then be an unknown after that. Mac VP states that those surfaces have to be smooth & flat on both front and rear if you want it to last and I pretty much agree.
Old 12-30-2017, 12:07 PM   #17
louisb
louisb's Avatar
Yeah I plan to call Vanpelt's next week and see if he has a good case.
Thanks,
--louis
Old 12-30-2017, 12:25 PM   #18
Anteek29
Anteek29's Avatar
Real shame to discard worn transmission cases. Why can't an enterprising person set up tooling and rework them? I'd think this would be a great resource for rebuilders.
Alan
1929 Special Coupe
1941 Pick-Up
1955 Victoria
Anteek29 is offline   Reply With Quote
Old 12-30-2017, 12:35 PM   #19
flatheadmurre
flatheadmurre's Avatar
I sprayweld and machine it for you...only one catch...you can still find a good used one cheaper.
Don´t throw them away...they will become more scarce by the day.
Old 12-30-2017, 12:36 PM   #20
Russ/40
Russ/40's Avatar
No comment ?...?
