04-07-2014, 12:25 PM | #1 |
'32 Coupe does not sit level
What does one normally do when the car leans more on one side than the other. In this case, my 5W sits 3/4" lower on the 'wrong side...the driver side....to make it worse, the side we sit in driving alone mostly. The springs were changed to new...same problem as before. I tried rocking & rolling on the passenger side running board in an attempt to straighten...but stubborn car goes back where it wants. It's a stock frame and everything looks straight, but who knows. The only remedy I can think of is to make a wedge piece between the cross member and spring in order to level it. Seems to me that I had this problem many years ago...but memory fails as to what I did. I am sure I am not the only one here....as the level is totally dependent on the U-bolt attachments front & back. Would appreciate comments here....Robert
04-07-2014, 12:28 PM | #2 |
Re: '32 Coupe does not sit level
Try putting the frame only on jack stands and let the axles hang.. see if something is noticeable then.
Are your shackles the same on both sides for sure? Good luck! Zach
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
04-07-2014, 01:49 PM | #3 |
Jack up the rear with the jack centered under the rear end. If it sits level, the problem is in the rear. If it still leans, problem in front. Reach up and see if the square spring centerbolt heads are in the holes in the crossmembers. Sometimes they are not in place and the car will lean.
04-07-2014, 02:41 PM | #4 |
I believe the idea of having the car level on jack stands and checking the tire height as the wheels are not supported makes good sense. The only problem here is to make sure the shocks are not holding up the axles. Yes, all of the other tid-bits are OK...spring bolt head in the hole, shocks, shackle length, etc. If all fails to give results, I will machine out a fine wedge to place between x-member and spring...the more I think of this....the more I believe that I had already done this many, many moons ago. It's an easy fix...for me.
04-07-2014, 05:51 PM | #5 |
I to have used a wedge to level the car if all else fails. I've used aluminum pinion wedges from a front end shop.
04-08-2014, 08:10 AM | #6 |
Krylon 32....yep...back to wedge idea....Thanks. Anybody else out there with comments.....it seems that this is not a new problem with old Fords. |
04-08-2014, 08:47 AM | #7 |
Robert our 5 window had same issues front spring cracked , rear was also cracked , replaced both and still leaned looked at rear end panel under the rumble lid and that piece is out of line so it makes the car look uneven . I need to figure out how to aling this piece so the car does look level which it is , but doesn't look like it is . Hope this helps .
04-08-2014, 10:42 AM | #8 |
Try tightening the U bolt on the right side and/or loosening the bolt on the left in the rear. When I had my coupe it leaned also, when I got out I just pushed the body to the right and left it level. Back in the 60's didn't really care if it sat level.
Paul in CT |
