07-17-2013, 01:46 PM | #1 |
32 5-window r/window drain
Does anyone have a picture, diagram, measurements on the rear window drain of a 5-window 32 coupe?
On my project car I got the rear package tray, window & mechanism, wood and drain pan unattached to the car. I understand how it goes back in, but there seems to be an end and tube missing from the drain pan. The driver side has an end to block water from running out on that side, but the passenger side is open and no drain tube, I'm thinking(which is dangerous) that there should be a small piece of sheet metal on the open end with a tube running from it. Am I way off? This whole unit is too good to throw away and would rather use the original parts repaired. Also what is the tube made of, copper or steel? Any suggestions, measurements, pictures appreciated. |
07-17-2013, 06:28 PM | #2 |
Re: 32 5-window r/window drain
My 31 deluxe coupe roll down rear window has that same water drain setup. There is a little tube about one inch long about the size of a nickel on the right side. I just hooked a hose to that tube and run it down through a hole in the floor on the outside of the frame. Probably a clear plastic hose will last a lifetime. Walt
07-17-2013, 08:04 PM | #3 |
Hey Lou we also have a 5 window that I have apart to put safety glass in therear window . on the pass side there is a sheet metal cap with a hose elbow coming out for the hose to go through the floor . I will try to get some measurements and a picture of it tomorrow . Still not having much luck trying to get pics to post so be patient .
07-17-2013, 11:03 PM | #4 |
