Old 08-16-2023, 03:29 PM   #1
36Jim
36Jim's Avatar
Default 36 Mechanical break upgrade
Are there still kits out there for upgrading mechanical breaks to juice? Or even better disc?
36Jim is offline   Reply With Quote
Old 08-16-2023, 03:37 PM   #2
KiWinUS
KiWinUS's Avatar
Default Re: 36 Mechanical break upgrade
Yes 39-48 ford or the new Bendix. But why? I can lock all 4 wheels at 60mph on my stock 36 should I choose to. Just add floaters and fully adjust correctly.
Old 08-16-2023, 06:13 PM   #3
rg130
rg130's Avatar
Richard Lacy of the Early V8 Garage has a kit.
rg130 is offline   Reply With Quote
Old 08-16-2023, 09:13 PM   #4
38 coupe
38 coupe's Avatar
X2 on good stock brakes. Use the correct linings, adjust properly, and drive happy.
Old 08-17-2023, 10:34 AM   #5
ndnchf
ndnchf's Avatar
My '35 Fordor has these floaters and they work great. My car feels like it has modern brakes.
ndnchf is offline   Reply With Quote
Old 08-17-2023, 10:53 AM   #6
petehoovie
petehoovie's Avatar
Old 08-17-2023, 12:41 PM   #7
JM 35 Sedan
JM 35 Sedan's Avatar
That's the same type of floaters/equalizers that I have on my '35 fordor slantback sedan (FB Avatar) and they also work fine for me.
John
Old 08-17-2023, 12:43 PM   #8
doghair3
I have never seen that type of floater before. What type are they? I would be interested in learning more.
doghair3 is offline   Reply With Quote
Old 08-17-2023, 12:57 PM   #9
ndnchf
ndnchf's Avatar
I think is the box for the floaters. And shown on my '35 front brake.
Old 08-17-2023, 12:58 PM   #10
ndnchf
ndnchf's Avatar
Instructions.
File Type: jpg 35-38 brake floater instructions (1).jpg (65.2 KB, 272 views)
Old 08-17-2023, 01:08 PM   #11
petehoovie
petehoovie's Avatar
Old 08-17-2023, 01:09 PM   #12
petehoovie
petehoovie's Avatar
Instructions.
Old 08-20-2023, 04:40 PM   #13
FlatheadTed
FlatheadTed's Avatar
My kit
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 08-20-2023, 04:45 PM   #14
Rockymountainsparky
I'm sorry but what are floaters? Do they improve the braking force with manual type brakes?
Rockymountainsparky is offline   Reply With Quote
Old 08-21-2023, 08:35 PM   #15
Yoyodyne
Yoyodyne's Avatar
Where can I buy those?
Yoyodyne is offline   Reply With Quote
Old 08-21-2023, 09:07 PM   #16
Kurt in NJ
Kurt in NJ's Avatar
ford factory floaters
After having a 39,and 46 I got the 36 because it has the mechanical brakes upgrade.
File Type: jpg 8FD798CE-BC5B-4320-830E-BD77601EDFE2.jpg (58.9 KB, 21 views)
Old 08-21-2023, 09:11 PM   #17
38 coupe
38 coupe's Avatar
Floaters convert the fixed anchor brake shoes to floating brake shoes. That allows the brake shoes to self center in the drum. Fixed anchor shoes require careful adjustment which is very tedious and usually difficult. If the fixed anchor shoes are not perfectly centered in the drum then only part of the friction lining acts on the drum. Floating shoes result in all the friction lining of the shoes up against the drum slowing the car down.
Old 08-21-2023, 10:10 PM   #18
elwood
elwood's Avatar
I use Teds kits, Ive installed 4 sets in the last 3 years, crazy good.
Can lock em all up at once, and at that point with any type system, you can only stop as fast as your tires are sticking..
elwood is offline   Reply With Quote
Old 08-22-2023, 08:14 AM   #19
JM 35 Sedan
Good explanation!!
John
Old 08-22-2023, 10:35 PM   #20
Rockymountainsparky
Wow! That sounds like something I would like to do to my 36 coupe. Any suggestions on a floater kit?
