07-30-2019, 04:08 PM | #41 | |
Re: Flathead deck height
I will update my CAD model to include a rough block outline and some of the other critical dimensions. Though everything previously mentioned about CH and the values for stocking stroke lengths remains the same and the drawings that I show and the associated dimensions (for the geometry depicted) should be correct. |
07-30-2019, 05:09 PM | #42 |
I've got a box of Silv O Lite pistons for a 3 3/4 stroke engine. The box says CH is 1.702. The actual measurement is 1.507 which would put it below the the deck by .054.
07-30-2019, 06:47 PM | #43 |
Interesting - this is exactly why knowing the CH needed for a given crank, rod, stroke combination is the key number. It is all I've ever used in ordering pistons (or designing them in CAD and giving the prints to the piston manufacturer). Well to be clear - that is referring to the location of the top of the piston . . . there is a lot more to know for the rest! LOL
07-30-2019, 07:45 PM | #44 |
Thank you everyone, especially B&S and Yoyodyne. I'm going with 10.440/10.445.
I believe the Ford 9N,2N & 8N, 4 cyl engine, also used the same piston. I collect tractors and I found a set, this morning, for the 8N. Measuring from the pin edge to the start of the dome, I got 1.155, that makes it 1.530. Based on that, I believe that TRW had a typo and their dimension should have been 1.527, instead of 1.627. That would give a factory deck clearance of .038/.043 (sounds reasonable)but, that needs to be verified. B&S, how do you access the factory drawings? Frank |
07-30-2019, 08:07 PM | #45 | |
If someone requests a particular compression ration, using o/s pistons, they have to adjust the C/H to compensate for the C/R. Frank |
07-30-2019, 08:37 PM | #46 | |
What we tend to do is manipulate chamber volume to setup/control compression. Truth be told, most of us wish we had more - hard to do with the typical aftermarket head - unless you have a large cubic inch engine OR we're running a blown application on gas (then we might buy heads with larger chambers - which are available from a few folks). |
07-30-2019, 09:39 PM | #47 | |
There are CR tables for different configurations, but they are somewhat of a guess, there are a lot of variables. Hard to do much CR wise with stock bore and stroke. |
07-30-2019, 10:04 PM | #48 |
The problem is if the piston is below the deck, it's tough to get the tight quench at the edge of the chamber.
07-30-2019, 11:59 PM | #49 |
I'd love to see what tools Ford used to check that dimension and some other difficult features on the flathead in the early '30s.
07-31-2019, 01:58 AM | #50 | |
Those things existed in the 30's and before. As I posted before, this is how it's done: You lay the blocks deck on the surface plate, modern surface plates are measured in the millionth of a inch for flatness and modern surface plates are made of lapped granite but in that period, cast iron surface plates, were more common. They would be made by surface grinding and lapping. You then, measure the distance, from the surface plate, to the bottom of the main bearing bore and add 1/2 of that bore to your measurement. If your height gauge, measures in millionth's, you then have that accuracy in your measurement. To maintain that kind of accuracy, it also has to be done, in a temperature controlled room. The standard measuring temp, is 20C. All those thing don't sound like much but, steel and cast iron, expand at a rate of ~.000006, per inch, per degree F. If you, while machining a part, increase the temp of a part by 100F, that is 20" long (like say a engine block), that makes a difference of .012. The deck height would increase .006, also. So when they are measured the temp is important. Aluminum expands at about 3 times what steel does so, that has to be dealt with when using metals with different expansion rates, such as pistons. Ford's manufacturing wasn't done with automotive type equipment, like you find in a automotive machine shop, it was done on milling machines, lathes, horizontal boring mills and planers, as well as other common, manufacturing machines. Frank Last edited by frnkeore; 07-31-2019 at 02:06 AM. |
07-31-2019, 03:46 AM | #51 | |
Now - would be interesting to know how you officially measure the deck on a 409? Where on the deck??? |
07-31-2019, 07:59 AM | #52 | |
07-31-2019, 10:18 AM | #53 | |
07-31-2019, 10:40 AM | #54 |
There are some good films converted to digital video but you don't see a lot about the machine shop at the Rouge. Ford had some of the best tooling in the industry so they could mass produce. I'd figure with a strong percentage of certainty that they had gauges made to check stuff like that. The measuring equipment would have been designed for the specific job. Whether it was done at a line inspection station or actually in the machines that did the work would be unknown to me but everything was designed around the quickest possible check of a dimension so that the line could keep on moving at a steady pace. Those big planing machine cutting blades they used wear down over time so it would be important to check up on that so that tooling could be quickly serviced with minimal discrepancy to the finished parts. Charles Sorenson mentioned in his book that they had serviceability rates that were among the highest in the industry with very small percentage of discrepancies in the finished product.
