09-26-2017, 11:21 AM | #1 |
Swedging and turning drums
Hello All,
Does anyone know who can do this in the High Desert, IE, OC or LA basin? I also need a place to have my spindles honed for new king pins. How much should I expect to pay for these services? Regards Bill |
09-26-2017, 11:29 AM | #2 |
Re: Swedging and turning drums
Randy Gross is the name I keep seeing in regards to Model A drum brakes in the LA area. I'm going to get a set of drums on my hubs from him pretty soon.
Nathan - 1929 Closed Cab Pickup, 1929 Tudor, 1930 Coupe, 1941 Pickup - Vintage BMW Motorcycle Collector/Mechanic |
09-26-2017, 11:36 AM | #3 |
09-26-2017, 11:37 AM | #4 |
Yes Randy Gross for brakes. I bought a set. Excellent product and excellent service.
https://www.fordbarn.com/forum/showthread.php?t=228940 I'd sure ask him about the spindles.....
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
09-26-2017, 12:15 PM | #5 |
Whoo-Hoo!
Thank you Gentleman, … I Called them up and spoke to Randy, Mel's son. I will be going over to their place on Saturday. FIY, … He said No, He doesn't do work on King Pin's. 1955cj5; Posting the info and link and price for new drums was perfect, ... Thank You! Regards Bill |
09-26-2017, 01:42 PM | #6 |
BTW, I'm using a temporary front end on my 28, and the king pins are so worn that I can move the tops of the tires in and out about an inch, and yet the car steers great, and has never had the death wobble. |
09-26-2017, 11:44 PM | #7 |
Most any automotive machine shop can hone the king pin bushings.
They can do it with the same machine they use to hone piston pin bores. Chris W. |
09-27-2017, 04:06 PM | #8 |
I think honing king pin bushes is fine but use a reamer first. A hone will only follow the shape that is already there. If it is out of round or even a burr on the bush from fitting it, the hone will leave the ID out of shape. Ream it till you have a full cut and stop while it is a bit too tight. A ream is fine from there on but make sure you don't leave the bush too tight. You will never control the car when you hit the road.
09-28-2017, 02:35 AM | #9 | |
09-28-2017, 08:03 PM | #10 |
Does someone have a part number for the reamer? Where to purchase?
09-28-2017, 08:55 PM | #11 | |
http://www.snydersantiqueauto.com/king-pin-reamer My friend who has helped me throughout learning about Model A's had one, not exactly like Snyder's but it worked great....we did mine and they turned out really nice. If you get one of the repop kingpin kits get some extra shims..I needed them as the repop pins are the tiniest bit longer than the originals.... .
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 Last edited by 1955cj5; 09-28-2017 at 09:05 PM. |
09-29-2017, 02:05 AM | #12 | |
