01-01-2018, 11:06 PM | #1 |
Radiator Repair: Soldering 'Contaminated' Cast Iron Neck
So far I've done a lot of work on a 1940 honeycomb radiator for my late '30 CCPU. This is my first radiator repair that I've taken to a multiple component disassembly level. One of the very last steps is to fix a leak between the upper tank and the cast iron inlet neck.
(See photo) When I removed the inlet neck there was rust at the seam, so it was easy to spot where the leak was. It actually looked like they didn't put enough solder on the joint! Cleaning the tank was fairly simple and only a smooth coat of solder was left when I finished. The iron inlet neck was another story. After I removed the old solder and the rusty crud, I noticed that the inlet neck mating surface was discolored. My guess is it's from embedded rust and/or old chemicals. I wire brushed it and cleaned it with MEK, but the discoloration remained. I attempted to tin the surface and the solder did stick, but it didn't want to flow. I'm guessing something is still on there. Any ideas for cleaning the cast iron neck? Sand blast? Acid? But wait, there's more! The tanks mating surface for the inlet neck has a wave in it. Not major, but enough of a gap to keep the solder from sealing it up. If push comes to shove, before I solder it I'll put some small screws into it to close the seam gap...but that's my 'last-ditch bail-out' move. Any better ideas?
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
01-02-2018, 01:45 AM | #2 |
Re: Radiator Repair: Soldering 'Contaminated' Cast Iron Neck
1930-pickup
sand blast and then clean with muretic acid then tin it. In my dads shop we would use brass exploding rivets if push comes to shove. Not sure now where you can get them. Ed |
01-02-2018, 09:43 AM | #3 |
You need to flux the joint for solder to stick, get the flux that is compatible with the solder you are using ! You should be able to fill the gap by multiple attempts :-)
01-02-2018, 09:46 AM | #4 |
Ed. Would you care to explain what a "brass exploding rivet" is. Never heard of it. Jack
01-02-2018, 11:48 AM | #5 | |
Bob |
01-02-2018, 03:28 PM | #6 |
The tricky part will be getting the heat into the neck without over heating it and burning off the solder. John Poole |
01-02-2018, 03:39 PM | #7 |
Thanks Ed
01-02-2018, 05:56 PM | #8 |
As a last resort, are you up to fabricating a brass replacement or even using the old piece as a pattern and having a new brass one cast. I'm sure you could sell a few if you made extra.
01-02-2018, 06:20 PM | #9 |
Only if you can identify the manufacturer of this radiator, and the quantity still out there today, and how many of those need an inlet neck.
01-02-2018, 10:08 PM | #10 |
Is the neck different from other radiators? If so, is it possible to make one that will do both? Just an idea. The final decision is yours.
01-03-2018, 12:52 AM | #11 |
High tin content solder will flow & stick a lot better in the spaces that' aren't close enough for 50/50%.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
